Could there be any way of having the lyrics displayed automatically when opening the music visualization screen? Right now I have to press M and look for the right button. Perhaps editing some xml file? Thanks in advance for your help...
Following this thread to see if there is a solution as I could definitely make use of it too.
Add this to MusicVisualisation.xml before the <controls> tag:
<onload>RunScript(script.cu.lrclyrics)</onload>
(2013-03-27, 20:42)Big_Noid Wrote: [ -> ]Add this to MusicVisualisation.xml before the <controls> tag:
Thank you, it worked like a charm...
I must confess that now and then I try others skins, but I always go back to Nox, it's simply the best, congratulations Big_Noid
I dont know if its just me or what but I can't get the lyrics to work period in Nox. It always says "Choose Song" with nothing to select. Lyrics work fine on any other skin.
Anybody else have this issue?
I have exactly the same problem. If I switch to another skin the lyrics work fine so it seems related to Aeon Nox.
Dunno if it helps you guys but I had similar issue some time ago and I deleted the Aeon skin folder and re-downloaded the skin.
That worked for me.
I'm using Confluence Mod 2 on Frodo 3.0.5 and this works great to show the lyrics when I, for example, start playing a playlist. When it changes to the second and subsequent songs the lyrics aren't displayed.
Any ideas how to turn on lyrics and keep them on for all songs?
Didn't get this to work with Aeon Nox, but I changed the keymap.xml to display the lyrics on a specific keystroke.
(2013-04-22, 14:48)thatguy188 Wrote: [ -> ]I dont know if its just me or what but I can't get the lyrics to work period in Nox. It always says "Choose Song" with nothing to select. Lyrics work fine on any other skin.
solution is here
http://forum.xbmc.org/showthread.php?tid...pid1287370
(2013-06-12, 13:45)gargamon Wrote: [ -> ] (2013-03-27, 20:42)Big_Noid Wrote: [ -> ]Add this to MusicVisualisation.xml before the <controls> tag:
This! Anyone an idea?
using Quartz on Raspi
