2014-07-27, 13:50
2014-07-28, 13:51
(2014-07-27, 13:50)KRA77 Wrote: [ -> ]Would really like to see this updated with m3u support that is in tvh now.
Which m3u support do you mean and how should it be integrated?
2014-07-28, 14:03
In current git versions of tvh (web gui). The browser download m3u file when you click play.
2014-08-02, 06:50
Hi!
Very usefull. I'd like to change the colour of background where icons are displayed since I'am using transparent icons optimized for darker background and some are not seen on white one.
This is the couse i'd like to change the background, but only of the area where the icons are displayed.
tnx
tnx
2014-08-18, 12:59
Hi illiac4,
you can now use black backgrounds for icons. Please update the files from github and set blackLogo in mobile/tvh_custom.js to true.
2014-08-19, 05:28
(2014-08-18, 12:59)xoox Wrote: [ -> ]Hi illiac4,
I have tried and it does not work. Have updated to the latests changed the blackLogo to true and it is still white.
Tried in Chrome an IE and in both it is still white.
2014-08-19, 14:05
tvheadend-4.0 branch or master?
2014-08-19, 14:41
3.4.7 final
2014-08-20, 13:48
On what versions does this work?
Have it installed on version 3.9.1281 and when opening index.html it retruns: 1 Unknown returncode
2014-08-20, 23:02
How you made the connection with the tvheadend imdb? As shows the cover of the movie? And so much information
2014-08-27, 11:43
(2014-08-20, 23:02)iorifly Wrote: [ -> ]How you made the connection with the tvheadend imdb? As shows the cover of the movie? And so much informationYou have to fill in a valid TMDB API key in tvh_custom.js for Covers and Background in Timeline view. The rest of the information comes from Tvheadend (OTA EPG).
(2014-08-20, 13:48)schumi2004 Wrote: [ -> ]On what versions does this work?There are two branches: master and tvheadend-4.0. For current git versions of tvheadend you have to use the branch tvheadend-4.0.
(2014-08-19, 05:28)illiac4 Wrote: [ -> ]I have tried and it does not work. Have updated to the latests changed the blackLogo to true and it is still white.Works for me. Perhaps a browser caching problem? Try to delete the browser cache.
2014-10-01, 00:20
I'm mystified. Under version HTS Tvheadend 3.9.1553~g6a86c96~wheezy neither version of this addon seems to work. I can get the index.html page to appear, and if I click on Mobile UI that comes up, but if I click Timeline I just get a blank white page, and if I click Listings I see a grid with times on the left hand side but there is nothing in the grid.
I obtained the program by going to https://github.com/polini/TvheadendMobileUI and downloading the zip file, then (as root) copying the mobile directory from the zip file to /usr/share/tvheadend/src/webui/static/mobile. I assume I did it right since the index page comes up, but it simply appears that it isn't able to fetch any data from TVHeadEnd. I also tried the version at https://github.com/polini/TvheadendMobil...eadend-4.0 and it behaved exactly the same way.
Which version of the addon should I be using with HTS Tvheadend 3.9.1553~g6a86c96~wheezy, and how do I get it to work? Are there any dependencies or anything that need to be installed?
Also, are there any similar addons designed to bring a grid view (similar to what you see in XBMC) to the desktop web-based UI?
2014-10-26, 02:26
(2014-10-01, 00:20)xbmclinuxuser Wrote: [ -> ]I'm mystified. Under version HTS Tvheadend 3.9.1553~g6a86c96~wheezy neither version of this addon seems to work. I can get the index.html page to appear, and if I click on Mobile UI that comes up, but if I click Timeline I just get a blank white page, and if I click Listings I see a grid with times on the left hand side but there is nothing in the grid.
Same here i'm running Tvheadend 3.9.1780
2014-10-27, 11:27
I truly recommend using a native app instead of this 2 years old and outdated web interface.
iOS:
https://itunes.apple.com/en/app/tvhclien...00112?mt=8
Android:
https://play.google.com/store/apps/detai....tvhclient
iOS:
Android:
2014-10-27, 11:32
(2014-10-27, 11:27)Cassiel Wrote: [ -> ]I truly recommend using a native app instead of this 2 years old and outdated web interface.
iOS:
Android:
Thanks for the link. Didn't knew about TVHClient for Android.
I always used https://play.google.com/store/apps/detai...d.tvhguide
