Full Version: Changelog
Pages: 1 2 3 4 5 6
15.06.2016 - Version 2.8.1
x do not reset certification style to SHORT
x remove movies without VIDEO files after update data sources
x follow symlinks with our new "update datasource" logic
x fixed loading of TV show special season posters
x fixed reading codec of Microsoft VC-1 via MediaInfo
x fixed update single datasource for movies
x fixed renaming movies with colon
x prefer MI data from common video types over disc image types
x fixed a bug in the renamer where renaming did not work
19.07.2016 - Version 2.8.2
+ MediaInfo for ISO files - yay!
+ reworked command line scraping, please check syntax (add scrapeAll, reworked logic for TvShows)
+ added select all/deselect all buttons for metadata scrape options
+ added persian to the scraper languages
+ added telecine, R5 and stream to media sources
+ added extra language setting for subtitle scraping
+ support folder excluding in Kodi style (.nomedia file in folder to exclude)
+ added media source renamer token for TV shows
+ updated tmdb scraper (thanks to @davidsben)
+ updated extras detection to Plex naming scheme
+ IMDB scraper: option to scrape local release date or global release date
x fixed movie renamer dropping several image/NFO files
x TMDB crash when scraping of several TV shows without artwork
x fixed exporting of movies/TV shows
x fixed TV show multi-file episode detection
x fixed updating of tags in the UI
x rename .idx files along with with .sub files
x improved writing/reading speed for subtitles and NFO files
x do not overwrite external Kodi NFO streamdetails
x overwrite existing images in the exporter
x fix for renaming into subfolders
x fixed wrong scraped release dates (where no release date has been found)
x fixed TV episode detection for extracted disc files
x changed the NFO column to better indicate scraped/unscraped movies
x better detection of movie name out of filename
15.08.2016 - Version 2.8.3
+ movies: created an own column for available meta data (reverted logic for NFO column)
+ Take year differences more into account, when comparing scraper search results
+ Do not download default movie poster/fanart, if none selected.
+ Do not write NFO, if none selected.
+ better visualize running tasks
+ Added some memory stats to status bar
x fix MediaInfo crash on some DVD ISOs
x fix TV Episode NFOs for extracted DVDs
x fix CMD line updating of TV shows
x fix episode root path for extracted disc folders
x fix adding/removing manual subtitle to media files
x fix certification on rereading NFO
x fix extracting export templates
x fix TvShow NFO import when empty production company
x fix manual sort title (reseted to empty on every save)
x able to handle windows "junction" linked files (deduplication)
x better visualize WakeOnLan menu item (disable when none found)
27.10.2016 - Version 2.9
SCRAPER CHANGES:
You now have the option to scrape localized language/country names instead of ISO codes
!Check your scraper config (IMDB/TMDB/MovieMeter.nl)!
MOVIE SET CHANGES:
Due to recent changes in Kodi we've changed our internal handling of movie sets:
- the sorttitle of movies in a movie set is no longer used
(tinyMediaManager and Kodi use the release date to sort)
- tinyMediaManager now supports the new NFO style for movie sets
(reading & writing; we also support reading the old style for importing)
! Due to the NFO changes and sorttitle changes you should rewrite the NFO !
! files of your movies if you use movie sets! (Don't forget to re-import your movies in Kodi) !
+ MediaInfo: parse pre-generated XMLs (mainly needed for ISO files)
+ added support for clearlogos
+ added a date picker for easier date editing
+ added automatic download of extra artwork for movie sets
+ implemented filtering for multiple tags (movie & TV shows)
+ implemented filtering for multiple datasources (movie & TV shows)
+ added play button in the movie chooser
+ added scraping of movie set artwork from fanart.tv
+ added connection throttling for anidb
+ added theatrical to movie editions
x fixed subtitle downloading where language tag got stripped off
x fixed a UI glitch in the movie renamer settings when no folder name has been chosen
x fixed Kodi scraper detection on MacOS
x some improvements to the TV show renamer
x fixed update of offline data sources
x fixed an occasional multi threading problem (ConcurrentModificationException)
x fixed loading of online movie set artwork (if no local artwork has been found)
x adhere graphic settings better for multiple movies in one directory / disc folders
x added filter indicator for TV shows too
x fixed detection of episode files
x improved episode name detection at import
x fixed renaming TvShows on CMD line
x fixed downloading of empty movie set image files
x fixed changing the default scraper in the episode editor dialog
x many internal changes....
Version 2.9.1
+ added Trakt.tv scraper
+ added option in the bulk renamer to set/clear the sort title
+ updated libmediainfo to 0.7.90
+/x added escaping of file names/urls in the movie exporter
x fixed loading of plugins from a network share
x added a connector for XBMC/Kodi < v16
x fixed some UI scaling issues
x fixed NFO writing for multi movie folders
x fixed settings for Turkish language (#102)
x fixed renaming in case insensitive file systems (#101)
x respect renamer settings for subtitle language tag when downloading
x fixed language code detection (#107);
(user with swedish subs may have to rename their subs after upgrading!)
27.01.2017 - Version 2.9.2
+ added action: download missing artwork
+ added parsing of Synology VSMETA files
+ added shortcut (CTRL - F) to jump to the search field (thx @hampelratte)
+ improved user interaction for tags and genres (thx @hampelratte)
+ get a list of video files for TV show export with episode.videoFiles
+ added HDRip as an own media source
+ movie renamer: added $K token (first tag)
+ added moving of genres/tag in the movie editor
x fixed localized artwork loading for brazilian users
x fixed deleting of backup folder in windows #120
x fixed detection/renaming of movieset artwork in movie folders #111
x do not remove movie set artwork when removing movies from tmm #111
x do not remove movie sets when removing movies/data sources from tmm #111
x increased max memory setting for 64bit users to 2560MB
x updated MediaInfo to 0.7.91
x fixed parsing of media source
03.04.2017 - Version 2.9.3
+ EXPERIMENTAL: UPnP support - https://goo.gl/NieeJ8
+ updated libmediainfo to 0.7.94
+ changed display of runtime in media files tab to a shorter version with seconds
+ updated Trakt, now being able to scrape in user language (if available)
+ correct wrong TVDB entries, where year is specified in title
+ added movie edition to the NFOs
+ remember some choices you do in the UI (like chosen export folder, export template, ...)
+ added warning when exporting to a non empty directory
+ added button for TV show renamer in the top bar
+ enhanced video format detection #131
+ added "update single movie" (in addition of update datasource)
+ movie list: the indicator for missing artwork now respects your settings (poster/fanart only!)
+ some scraper can now scrape with the first aired date in addition to season/episode number
+ added movie sorting by release date
+ added spoken languages to MediaPortal NFO
+ write media source to episode NFOs too
x enhanced season/episode parser
x fixed several crashes when pressing the play button #139
x fixed stacking detection #132
x fixed some Trakt.tv syncing issues #137
x fixed searching for movie set id in movie set editor
x fixed scraping localized countries #110
x automatically drop corrupt entries from the database
x fixed actor image writing
x fixed movie renamer token $1/$2 to use first alpha numeric character
x fixed Plex trailers wrongly detected as extras #135
x fix thumb image naming for disc style episodes
x fix renaming of disc style episodes
x fixed start of playback on several linux systems
x fixed movie renamer where trailing dots have been truncated for folders
x fixed writing of .actors thumbs
x fixed reading of mediainfo.xml
x fixed movie sorting
x changed appearance of the subtitle download button #140 #119
x fixed searching for TV show actors in the UI filter
you may need to restart tinyMediaManager once after the update
Full Changelog: https://github.com/tinyMediaManager/tiny...er-2.9.3.1
25.08.2017 - Version 2.9.4
HIGHLIGHTS:
+ Kodi XML scrapers for TV shows! (Donator only)
+ MediaInfo changes: if you have high-res, 6+ channel, 4k files,
it is recommended to do a "mediainfo reload" of all movies, to get the correct icons.
+ Animated poster scraping (not always visible inside TMM, but on filesystem)
+ OMDb API scraper. Private scraper: details at http://www.omdbapi.com/ (thx @wjanes) - https://goo.gl/Duzhc6
TinyMediaManager offers a limited access to OMDb API (10 calls per 15 seconds)
- removed the RottenTomates scraper because this service is no longer available for public usage
+ updated libmediainfo to 0.7.98
+ export movies/tv shows via command line #116
+ added fallback language scraping with tmdb scraper (thx @ProIcons) - https://goo.gl/a87VZc
+ fixed various templates to use correct graphics
+ added new templates
DeadSix27 HTML generator by DeadSix27 - https://forum.kodi.tv/showthread.php?tid=160863
Mobile Movie Search by Jennifer Gigliotti
+ added more icons for high res audio & video streams (Atmos, TrueHD, DTS:X, 4k)
+ added UltraHD Blu Ray as media source
+ added .sup as subtitle format for new installations #162
(existing ones may have to add this file type in the settings)
+ added video bit depth from mediainfo
+ added more detailed video resolutions #181 (thx @Gridluck)
+ preload settings screen for faster startup
x enhanced autom. downloading of subtitles #157 (thx @ProIcons)
x fixed handling for nested movie structures
x fixed default value for copyArtwork exporting
x fixed TV multi episode renaming #143
x fixed handling of JPEG images
x fixed storing preference for episode scrape
x fixed deleting original graphics on cache-miss
x changed forum links to the kodi.tv domain #155
x fixed some things in the image cache #153
x fix some surround audio icons #117
x fixed a mediaInformation JVM crash on some DVD ISO files
x fixed/enhanced media source detection #172 (thx @ProIcons)
x fixed detection of certain audio streams with mediainfo #173 (thx @ProIcons)
x fixed the year field in the editors: now you can set the year to zero
x better handling of network interruptions in the artwork downloader
x fixed default window size of the bug report dialog #184 (thx @ProIcons)
05.10.2017 - Version 2.9.5
+ added some more (common) languages to the available scraper languages
x adapt IMDB site changes; getting plot works again
x fix fanart.tv scraping (thread crash)
x fix TMDB actor naming scrape
x fix ANIDB scraper (no episode/season fetched)
x fix Kodi scraper
x fix of the bug report dialog (saving log files and layout)
x some minor fixes
10.12.2017 - Version 2.9.6
+ add persian language
+ added option to include external audio files in Kodi NFO streamdetails (thx @midgetspy)
+ support for mediainfo 17.10+ XMLs
+ updated mediainfo to 17.10
+ fixed java 9 compatibility issues
x fix parsing MediaInfo for .ISO files (endless hanging sometimes)
x reduced log output on the console for the command line version
x fix animated pictures scraper; did not work on automatic scrape
x fix AniDB scrape (too much results)
x fix country tags in NFO (now multiple)
x change episodeguide url in TvShow NFOs
x cleaning of orphaned episodes in the database
x storing of episodes in special seasons (season 0) no more switches to season -1
x fix occassional crashes when writing objects to the database
x fix audio codes parsing of audio files (thx @midgetspy)
x fix renaming of movies with renamer token $2 and starting with umlauts
28.12.2017 - Version 2.9.7
+ added DataTables export template - thx to @C. Janke
x fixed the imdb scraper (imdb changed their web pages) - thx to @Grizzler89
x fixed a parsing problem in the Kodi scraper
x fixed movie renamer with animated posters
08.02.2018 - Version 2.9.8
+ added frame rate from mediainfo
+ updated libmediainfo to 17.12
+ show result window of the "find missing movies" feature
x fix IMDB language, release date and episode thumb parsing
x fix parsing audio channel information
x fix naming detection for 4k files
x fix Kodi scraper plugins unicode decoding
x improve Kodi scraper plugins http requests (correct headers)
x added more java 9 compatibility options
x fixed cancelling of actor image downloads
x added 2160p to file name cleanup
23.04.2018 - Version 2.9.9
+ removed usage of Google Analytics
+ added hebrew as media language (thx to @israelio)
x several fixes in the OSX starter script
x fixed opening of dialogs without parents
x fixed occasional errors on closing
x fixed downloading extrafanart/extrathumbs after network failures
x improved downloading of artwork from movie/TV show editors
x fixed auto select the first search result in the search windows
x fixed sorting of movies in movie sets
x fixed IMDB parsing from movie NFOs
x improved IMDB scraping original titles
x improved episode title detection (cleanup)
26.04.2018 - Version 2.9.10
+ feature: Kodi plugins now able to download images (movies)
x fixed registering donator version
05.05.2018 - Version 2.9.11
x added Ł and ł in the ascii replacer
x changed tvdb API to version 2
Pages: 1 2 3 4 5 6
