2013-11-04, 15:01
2013-11-04, 15:23
Pmolson,
Would you please help crusader88 with his atv issue as you got yours working
2013-11-04, 16:45
Hi Bisha,
It is for sure free and will stay free
2013-11-17, 19:30
if somebody still have problem to play Shahid MBC on Android, try to use this version of XBMC.
since I use it, i do not have any problem with youtube , Navi-x and shahid
thanks go to lewy20041
http://www.mediafire.com/download/4j9215...XBMCv2.apk
from here reply #127
http://www.minixforums.com/threads/justx...777/page-7
2013-12-05, 00:35
Hi Hussein, first of all thank you for the very nice work!
I have a problem since yesterday, the shahid addon don't show any content.
Thank you in advance
2013-12-05, 18:51
(2013-12-05, 00:35)sizar Wrote: [ -> ]Hi Hussein, first of all thank you for the very nice work!for me too. I hope, hussein can fix it
2013-12-06, 21:38
Hi Bisha
Any way we can get Dream 2 & 3 channels
2013-12-07, 02:25
Hi Hussein,
When I open Shahid MBC the repo is empty.Would you please take a look at it.I'm using windows( I also tried on Android and it's the same).
2013-12-07, 13:41
LFCFAN,
MBC had changed the site structure so I need to update the plugin. Meanwhile, there is another plugin for shahid under Arabic repo and I think it is working fine.
2013-12-07, 20:31
Hussein,
Even though,you spoiled me with yours I will keep entertaining myself with that one while you get the chance to update this one.
Thank you
Thank you
2013-12-10, 10:37
Shahid stopped working. Please attend to it when you get a chance. Thanks in advance!
2013-12-10, 18:00
pmolson,
There was a complete makeover for Shahed.mbc.net. I have done a partial quick fixup which should fix the the channels "القنوات". I will try to fix the rest ASAP.
2013-12-10, 18:23
(2013-12-10, 18:00)husseinb Wrote: [ -> ]pmolson,
Thank you very much, Husseinb.
2013-12-10, 18:29
You are welcom LFCFAN,
I have also fixed the "most recent" item; but I am having trouble finding the most popular. It seems Shahid has removed it. Anyone has any idea about it!!!
2013-12-10, 20:30
Hello and thank you this awesome repo. I can't install the new Shahid MBC Arabic Plugin from the repo, the old one stopped working, there is nothing under channels anymore. please help and provide me with a direct download link. Thank you.
