Thank you husseinb! repped +1
Hello can you fix the addon its not working anymore
thank you
fouad796,
What is exactly not working?
for some strange reason i just cant find the voice (ahla sawt) under channel section in your plugin. on the website it is present but not in the plugin
the stream now is only in SD low quality which i cannot change it to HD as it used to be before any idea
Salam
i'm new to xbmc, and i have an ATV2
how do i install the repo, do i just add teh gethub to the source?
how do you install the repo and zip file ?
could you provide the steps please
i don't have windows, only linux
ok, so i used putty and installed xbmc, and the repo and shahid
but in shahid i do not see anything, am i supose to install anything else before viewing
Salam husseinb
Mate thank you for your effort, plugin arab science is not working script error. Please check and see If you have time to fix it.
Salams Guys,
Can anyone recommend a good addon / Repo for watching live Mecca / Medina broadcast?
anyone have any good arabic skins or backgrounds ??
All mbc1 links are not working using the shahid addon any fix for this ?
Dear husseinb,
Can you please look into okanime video plugin, at appears it no longer able to fetch the anime list.
Thank you for the hard work.
