Hello,
I'm planning to buy Zotac Nano ID62u ( 1007u Celeron based with Intel HD graphics ) for my HTPC use ( Playing 1080 videos/movies + MP3 Audio from a SMB network share ).
http://www.zotac.com/products/mini-pcs/z...tions.html
Are there any issues with installing latest version of OpenElec on it. Does anyone see any issues with this ? Are there any limitation I should be aware of?
Thanks in advance for all your replies.
-Max
I'm going to bump it, because I've exactly the same questions, but I'ld like to use a external 4Tb or 3Tb HDD instead.
And thanks in advance too!
i have it and running openelec. works like a charm out of the box, including the remote
(2014-01-10, 07:11)jpman Wrote: [ -> ]i have it and running openelec. works like a charm out of the box, including the remote
Thanks for your quick response..
What version of openelec are you using?
Any issue playing Mkv or m2ts files.
(2014-01-12, 04:00)max71 Wrote: [ -> ] (2014-01-10, 07:11)jpman Wrote: [ -> ]i have it and running openelec. works like a charm out of the box, including the remote
I am using Intel x86_64 3.2.4 from a USB stick. No issues with playing anything I throw at it as well.
One thing to note though is the included remote isn't great. However, it will turn the box on from shutdown out of the box. Boot times from off using a USB stick is approximately 13 seconds or so.
Have a similar question except I'm looking at ZBOXNANO-ID62-PLUS-U. Will there be any issues with this model and installing openelec? Any issues using this processor and chipset that I may have?
Zotac Nano Mini PC Intel Core 1007U Intel HD 4GB DDR3 500GB SATA3 HDMI WiFi BT4.0 GLAN USB3
Chipset Manufacturer Intel
Chipset NM70 Express
GPU Intel HD Graphics
CPU Compatibility Name Intel Processor (dual-core) (1.5 GHz)
Socket (integrated CPU)
Memory Memory Type DDR3
Memory Speed 1600 MHz
Slots 1 x 204-pin
Capacity 2GB DDR3 (up to 8GB)
3D API DirectX DirectX 10.1
OpenGL 3.1
Networking Ethernet 10/100/1000Mbps
WiFi 802.11n/g/b + Bluetooth 4.0
Audio
Combo Headphone / mini-Optical S/PDIF jack
Microphone jack
Storage Hard Drive 500GB 5400RPM HDD
Memory Card Reader 7-in-1 (MMC/SD/SDHC/SDXC/MS/MS Pro/xD)
Ports
HDMI 1
DisplayPort 1
SATA 1 x SATA 6Gb/s (occupied by hard drive)
eSATA 1
USB Ports
4 USB 2.0 (2 on front, 2 on back panel)
2 USB 3.0 (on back panel)
Cooler SmartFan
Form Factor mini-PC
OS Compatibility Windows 7/8 ready
Other Graphics Output 1 HDMI / 1 DisplayPort
Packaging Content
1 x ZOTAC ZBOX nano ID62 Plus
1 x MCE compatible remote
1 x WiFi antenna
1 x VESA mount
1 x AC adapter
1 x Power cord
1 x Warranty card
1 x User manual
1 x Driver CD
1 x mini-Optical-to-Optical
