2016-02-02, 23:00
hello in kodi v16 jarvis when someone enable audio dsp prossesing ask for an add on and then system crashes and cannot return back unless i reboot the whole machine what is this add on?
(2016-02-02, 23:00)dimosx Wrote: [ -> ]hello in kodi v16 jarvis when someone enable audio dsp prossesing ask for an add on and then system crashes and cannot return back unless i reboot the whole machine what is this add on?
(2016-02-02, 23:00)dimosx Wrote: [ -> ]hello in kodi v16 jarvis when someone enable audio dsp prossesing ask for an add on and then system crashes and cannot return back unless i reboot the whole machine what is this add on?Which OS did you use? Can you provide a log file?
(2016-02-28, 12:29)hismastersvoice Wrote: [ -> ]So far I know we currently do not ship adsp add-ons on Android. Sorry. But I plan to do a release this week for Android. Afterwards they should be available in our nightlies.(2016-02-02, 23:00)dimosx Wrote: [ -> ]hello in kodi v16 jarvis when someone enable audio dsp prossesing ask for an add on and then system crashes and cannot return back unless i reboot the whole machine what is this add on?
Same as mine with an android box. The 5.1 sound not working on the HDMI and SPDIF as well. Another player like MX player working well, so this is not a hardware bug. What can I do? Any help appriciated thx.
(2016-03-01, 06:08)LeKodeur Wrote: [ -> ]Same problem here on Kodi 16, Ubuntu 14.04 install ... and Kodi 16, Windows 10 install ... and Kodi 16, Android (Minix) install. Try enabling DSP and an error notification came-up, followed by Kodi 'suspended' (unresponsive).Hm...
(2016-03-02, 01:30)LeKodeur Wrote: [ -> ]My apologies, correct, after playing around and finding more info I got it working in Windows 10 (only) using the Confluence skin. I was using Aeon Nox and MQ 6 skins and was getting nowhere. However, my most relied-upon Kodi installs are under Linux OS (Ubuntu 14.04) ...Sorry I forgot to say that you should use Confluence, because for AudioDSP we created a new window and the other skins have to be adapted to get AudioDSP properly working. It's one of the drawbacks in our skin engine that every skin has to would need some effort to support new features. Same counts for the add-ons.
(2016-03-02, 01:30)LeKodeur Wrote: [ -> ]are there any ADSP addons for Kodi 16 Linux? Many thanks!Yeah sure if you know how to compile it
Quote: git clone https://github.com/xbmc/xbmc.git
git clone https://github.com/{org}/{addon-id}.git
cd {addon-id} && mkdir build && cd build
cmake -DADDONS_TO_BUILD={addon-id} -DADDON_SRC_PREFIX=../.. -DCMAKE_BUILD_TYPE=Debug -DCMAKE_INSTALL_PREFIX=../../xbmc/addons -DPACKAGE_ZIP=1 ../../xbmc/project/cmake/addons
make
git clone -b Jarvis https://github.com/xbmc/xbmc.git
$ sudo apt-get update && sudo apt-get install build-essential
$ git clone -b Jarvis https://github.com/xbmc/xbmc.git
$ git clone https://github.com/kodi-adsp/adsp.basic.git
$ cd adsp.basic && mkdir build && cd build
$ cmake -DADDONS_TO_BUILD=adsp.basic -DADDON_SRC_PREFIX=../.. -DCMAKE_BUILD_TYPE=Debug -DCMAKE_INSTALL_PREFIX=../../xbmc/addons -DPACKAGE_ZIP=1 ../../xbmc/project/cmake/addons
$ make
Could not find a package configuration file provided by "p8-platform" with
any of the following names:
p8-platformConfig.cmake
p8-platform-config.cmake
(2016-03-03, 08:37)LeKodeur Wrote: [ -> ]Tried but got the following error message when I typed "make", some 'p8-platformConfig' scripts are missing:
Code:$ sudo apt-get update && sudo apt-get install build-essential
$ make
ERROR:
Almost got there! ... would installing 'libplatform' help?Code:Could not find a package configuration file provided by "p8-platform" with
git clone https://github.com/kodi-adsp/adsp.basic.git -b v0.2.0
(2016-03-03, 23:22)LeKodeur Wrote: [ -> ]Will ADSP addons be eventually available for 'mainstream' Kodi on Linux or are they meant to be Windows only functionality (or for those who can compile without errors )? Currently, using Confluence Linux freezes Kodi if you try enabling the ADSP manager ... perhaps this option should be disabled in Linux version of Kodi so 'mainstream' users like myself don't get tricked trying to enable it and crash
(2016-03-06, 02:17)hemiutut Wrote: [ -> ]Hello wisler :
In that system you can be installed and where you can download adsp.XConvolver .
I use Windows 7 + APO equalizer but I would try KODI 16 Jarvis DSPlayer + adsp.XConvolver in Windows
Greetings from Spain and I apologize for my English.I am using the translator.
(2016-03-09, 17:16)wisler Wrote: [ -> ]No it will be available for all platforms, but developing in spare time for such many platforms is quite a huge task
Hmm... Linux should work, then you might have some issue with your installation. A log file with enabled debug mode would be helpful.
