Full Version: Experimental Google Music Addon
Hi -. I installed the latest alpha version which works. One question.
Is it possible to integrate te app directly into the kodi library.
Background of that:
I want to use kodi as a streaming client - so that I can remotely play my google music etc.
When currently kodi app I cannot see google music in the music section - so I cannot remotly control.
If this would work it will be perfect...
The 1.3 stopped working, now im using 1.4 alpha. I had to disable 2-step authentication for app to work properly. I wonder if its some miss config in my account, or its an app bug. Please make it working again, I feel pretty unsafe with 2 step verif off.
(2015-06-06, 18:51)lucasmatheus Wrote: [ -> ]The 1.3 stopped working, now im using 1.4 alpha. I had to disable 2-step authentication for app to work properly. I wonder if its some miss config in my account, or its an app bug. Please make it working again, I feel pretty unsafe with 2 step verif off.
I did the same thing. Hopefully there's a fix soon.
(2015-06-06, 09:05)cherup Wrote: [ -> ]Hi -. I installed the latest alpha version which works. One question.
Background of that:
You can use the Export option to create .strm files that can be played and browsed by kodi as music files. But you can't import into kodi library because kodi can't recognize its meta-data.
(2015-06-07, 00:59)djyoyo Wrote: [ -> ]
Have you tried creating an app specific password?
https://security.google.com/settings/sec...ppasswords
Quote:You can use the Export option to create .strm files that can be played and browsed by kodi as music files. But you can't import into kodi library because kodi can't recognize its meta-data.
Have checked this out - I only have seen my music files als .strm files. Is ist also possible to export the playlists, so that ideally I can see my playlist which I can start remotely on the kodi client ?
Hoping for a fix too, I use this app a lot.
(2015-06-07, 01:23)foreverguest Wrote: [ -> ]
Yes I tried this and it didn't work. It use to work fine, but stopped working recently.
Do you see any error in log?
First. I wanna thank foreverguest for this plugin, awesome stuff! Smile
Unfortunately, 1.4 ceases to work correctly?
No library exists, nor does anything, apart from a 'mix' or 'lucky mix'.
Kodi 14.1 Android here, and was working OK last week.
Hope you can find problem out OK, and again, many thx!
Could you check kodi's log for error messages.
(2015-06-15, 03:43)foreverguest Wrote: [ -> ]Could you check kodi's log for error messages.
Dunno if this helps?
PHP Code:
19:03:26 T:1907497520  NOTICE: -->Python Interpreter Initialized<--
19:03:26 T:1907497520  NOTICE: [GoogleMusicEXP-1.4~alpha4]  ARGV: ['plugin://plugin.audio.googlemusic.exp/''1''']
19:03:27 T:1907497520  NOTICE: [GoogleMusicEXP-1.4~alpha4Loading auth from cache
19
:03:27 T:1895195920  NOTICEThread BackgroundLoader startauto deletefalse
19
:03:31 T:1855602536  NOTICEThread LanguageInvoker startauto deletefalse
19
:03:31 T:1855602536  NOTICE: -->Python Interpreter Initialized<--
19:03:31 T:1855602536  NOTICE: [GoogleMusicEXP-1.4~alpha4]  ARGV: ['plugin://plugin.audio.googlemusic.exp/''2''?path=library']
19:03:31 T:1816603176  NOTICEThread BackgroundLoader startauto deletefalse
19
:03:34 T:1914782232  NOTICEThread LanguageInvoker startauto deletefalse
19
:03:34 T:1914782232  NOTICE: -->Python Interpreter Initialized<--
19:03:34 T:1914782232  NOTICE: [GoogleMusicEXP-1.4~alpha4]  ARGV: ['plugin://plugin.audio.googlemusic.exp/''3''?criteria=artist&path=filter']
19:03:34 T:1914517912  NOTICEThread BackgroundLoader startauto deletefalse
19
:03:36 T:1908088160  NOTICEThread LanguageInvoker startauto deletefalse
19
:03:36 T:1908088160  NOTICE: -->Python Interpreter Initialized<--
19:03:36 T:1908088160  NOTICE: [GoogleMusicEXP-1.4~alpha4]  ARGV: ['plugin://plugin.audio.googlemusic.exp/''4''?path=library']
19:03:36 T:1855198040  NOTICEThread BackgroundLoader startauto deletefalse
19
:03:41 T:1857914192  NOTICEPrevious line repeats 1 times.
19:03:41 T:1857914192   ERRORUnable to find plugin
19
:03:41 T:1781484120   ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting plugin://
19:03:41 T:1781484120   ERRORCGUIMediaWindow::GetDirectory(plugin://) failed
19:03:41 T:1914782232  NOTICEThread BackgroundLoader startauto deletefalse
19
:03:52 T:1914750512  NOTICEThread LanguageInvoker startauto deletefalse
No useful messages there.Undecided
Could you please try to clean cache, clean cookies and view library again then post full log to pastebin and share with me?
(2015-06-16, 03:13)foreverguest Wrote: [ -> ]No useful messages there.Undecided
Sure, done.
http://pastebin.com/95j5dEeY
Have you cleared the addon cache? Please use 'clean cache' in addon settings.
