Full Version: SoundCloud
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
(2015-06-07, 16:45)akuseru Wrote: [ -> ]Oh before I leave, in the same order, when this bug will be fixed, will it be possible to also display the artist artwork ? In fact, I never saw any artworks with this plugin, so I ask ^^
Keep up your good work, bromix. I use this addon every days, it's a must have.
Here are 2 screenshots with Isengard Wink
Tracks
Artists
Yes this is exactly what I mean. I think about updating openelec when it will come. Pain in the *** because it never auto-update ... I have to format and reinstall. But not the subject isn't it ? ^^
Thank you for all.
Is there any way to 'share' a soundcloud audio from your phone to Kodi (raspberry Pi)?
Just like you can open a youtube video on your phone and then share is to Kodi using Yatse remote. Soundcloud however wont pick up on the links I send to Kodi. Sad[/u]
(2015-06-15, 11:32)apexalpha Wrote: [ -> ]Is there any way to 'share' a soundcloud audio from your phone to Kodi (raspberry Pi)?
If you're using an android device -> with Yatse it should work. Yatse has support for SoundCloud URLs.
Version 2.0.0 (2015-08-01)
UPD: framework
Hello, please tell me whether there is in this app pagination stream? and how to install this app?
(2015-08-16, 11:27)SMotiv Wrote: [ -> ]Hello, please tell me whether there is in this app pagination stream? and how to install this app?
What?!? Sorry I don't understand what you want. The addon is available via the KODI repo.
I don't know how to install this app, how can I install it? (detail)
(2015-08-16, 11:50)SMotiv Wrote: [ -> ]I don't know how to install this app, how can I install it? (detail)
Use the search...everything is there
http://kodi.wiki/view/HOW-TO:Install_add-ons
Will I see my stream in the form of pages in my account soundcloud?
Why don't just test the addon Wink because I don't know what you mean by pages? If you're logged in, you can see your stream (paginated) like on SoundCloud.com.
Having an issue in version 2.0, and can't view my stream. Thanks!
00:32:54 T:7556  NOTICE: -->Python Interpreter Initialized<--
00:32:54 T:7556  NOTICE: [plugin.audio.soundcloud] Running: SoundCloud (2.0.0) on Isengard (15.1) with Python (2.7.8)
00:32:56 T:7556   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.AttributeError'>
                                            Error Contents: 'NoneType' object has no attribute 'get'
                                              File "C:\Users\Ryan\AppData\Roaming\Kodi\addons\plugin.audio.soundcloud\addon.py", line 6, in <module>
                                                nightcrawler.run(content.Provider())
                                              File "C:\Users\Ryan\AppData\Roaming\Kodi\addons\plugin.audio.soundcloud\resources\lib\nightcrawler\core\runner.py", line 47, in run
                                                result = provider.navigate(context)
                                              File "C:\Users\Ryan\AppData\Roaming\Kodi\addons\plugin.audio.soundcloud\resources\lib\nightcrawler\provider.py", line 174, in navigate
                                                result = method(context)
                                              File "C:\Users\Ryan\AppData\Roaming\Kodi\addons\plugin.audio.soundcloud\resources\lib\nightcrawler\core\nightcrawler_decorators.py", line 44, in wrapper
                                                return func(*args, **kwargs)
                                              File "C:\Users\Ryan\AppData\Roaming\Kodi\addons\plugin.audio.soundcloud\resources\lib\nightcrawler\core\nightcrawler_decorators.py", line 126, in wrapper
                                              File "C:\Users\Ryan\AppData\Roaming\Kodi\addons\plugin.audio.soundcloud\resources\lib\content\provider.py", line 481, in on_stream
                                                page_cursor=cursor)
                                              File "C:\Users\Ryan\AppData\Roaming\Kodi\addons\plugin.audio.soundcloud\resources\lib\nightcrawler\core\abstract_context.py", line 145, in cache_function
                                                return self.get_function_cache().get(seconds, func, *args, **keywords)
                                              File "C:\Users\Ryan\AppData\Roaming\Kodi\addons\plugin.audio.soundcloud\resources\lib\nightcrawler\storage\function_cache.py", line 107, in get
                                                cached_data = partial_func()
                                              File "C:\Users\Ryan\AppData\Roaming\Kodi\addons\plugin.audio.soundcloud\resources\lib\content\client.py", line 252, in get_stream
                                                return items.convert_to_items(response.json())
                                              File "C:\Users\Ryan\AppData\Roaming\Kodi\addons\plugin.audio.soundcloud\resources\lib\content\items.py", line 129, in convert_to_items
                                                item = convert_to_item(item)
                                              File "C:\Users\Ryan\AppData\Roaming\Kodi\addons\plugin.audio.soundcloud\resources\lib\content\items.py", line 84, in convert_to_item
                                                kind = json_item.get('kind', '')
                                            AttributeError: 'NoneType' object has no attribute 'get'
00:32:56 T:5544   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.audio.soundcloud/stream/
00:32:56 T:5544   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.audio.soundcloud/stream/) failed
00:32:56 T:4224  NOTICE: Thread LanguageInvoker start, auto delete: false
00:32:56 T:4224  NOTICE: -->Python Interpreter Initialized<--
00:32:56 T:4224  NOTICE: [plugin.audio.soundcloud] Running: SoundCloud (2.0.0) on Isengard (15.1) with Python (2.7.8)
00:32:56 T:9728  NOTICE: Thread BackgroundLoader start, auto delete: false
(2015-08-19, 09:38)ryantrip Wrote: [ -> ]Having an issue in version 2.0, and can't view my stream. Thanks!
                                                page_cursor=cursor)
https://github.com/bromix/plugin.audio.s.../issues/27
Can't reproduce the problem right now...but trying to Smile
(2015-08-21, 17:30)bromix Wrote: [ -> ]
                                                page_cursor=cursor)
It sorted itself out somehow... All is good!
Version 2.0.1 (2015-08-27)
[add] French (thx 2 Soullivaneuh)
[upd] moved to *.po files
[upd] Framework
