Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
Since a few hours soundcloud has stop working normally. Some tracks are playable, but the majority won't play anymore.
It seems to occur when the add-on tries to connect to the host : "cf-media.sndcdn.com"
Am I the only one experiencing this issue ?
Is the problem coming from soundcloud server, a change in the API or maybe it's related to the issue of the 07 november : "error saving track metadata", and the track I'm trying to listen hasn't its link updated yet...
So, hey, I'm using Kodi(16.1) for Android and I tried to listen something in Soundcloud's Kodi Addon and everytime I tried to play something it always crashes. No message error, nothing, he only gives the message "capturing signal"(Or something like that, I don't use the english version) and crashes. How can I fix it?
Image of the problem(It's in portuguese, sorry):
Hey there,
Is there any way to display SoundCloud content as a channel in the Music Library tree when connected to kodi with a DLNA client and search/play it from there to a DLNA renderer?
many thanks
cheers
Tgun
Some news (not great) but I thought the developer might like to know.
Using android SoundCloud app, to play on Kodi, usually share button, then Play On Kodi works 100%.
But from today it has stopped working. --possibly SoundCloud has changed something?
(I discovered this after finding out that SoundCloud has decreased bitrate of music playing on Android mobile app).
(2016-05-28, 15:28)biberesser Wrote: [ -> ] (2016-05-21, 19:22)hvalbrecht Wrote: [ -> ]Is there any way I can disable the SoundCloud logo overlay during fullscreen visualization?
Addon settings -> disable "Show Fanart"
i´m not finding this in kodi17? plz help
Hello !
I'm unable to connect Soundcloud plugin on my account.
I signed on Soundcloud with a gmail address, and always have an error when typing my credentials.
Any idea ?
Thank you !
hi guys
do you know why the soundcloud plugin does not work in kodi 16.1? if it is solved please help meeeee
Dear friend
Do you know why the SoundCloud plugin doesn't work on kodi 16.1 ?
soundcloud plugin doesnt work anymore since some weeks in Kodi 17.3 und 18 nightly, win 10. Login with own accound details doesnt work. it say http error. only general search works but no personal playlists and so on. Has someone a solution for this?
can confirm, logging in doesn't work. HTTP error 403 is returned. tried to curl the soundcloud api from the same box and get a good oauth2 token back. definitely something with the url library in python or its implementation in the plugin. searching, explore, and playing tracks, retrieving playlists, etc. all works.
(2017-08-31, 21:19)lwrcase Wrote: [ -> ]can confirm, logging in doesn't work. HTTP error 403 is returned. tried to curl the soundcloud api from the same box and get a good oauth2 token back. definitely something with the url library in python or its implementation in the plugin. searching, explore, and playing tracks, retrieving playlists, etc. all works.
To me searching doesnt work. It says error 404 and asks me to login, and no login credentials are being accepted. How did you manage to get it work?
Quote:To me searching doesnt work. It says error 404 and asks me to login, and no login credentials are being accepted. How did you manage to get it work?
Same thing here, no login possible, searching is not possible and returns 404. Would love to get a solution for that, liked to have SoundCloud in Kodi a lot.
