2014-11-26, 10:34
Solved: mkortsiegefound the culprit in mtime not being updated for folders on (some) ExFat devices thus not working wth the new fasthash method for scanning for new files.
From 14.2 onwards (as of the beta from feb 17th) you can force the old scanning method by inserting
into your advancedsettings.xml.
Thank you!
Hello everyone,
since beta 3 of Kodi 14 there seems to be a problem with library scanning for me. It just doesn't add any new files I placed in the directories.
When I bring up the context menu on a TV show, enter TV show information and "refresh for all items" it does find them however. It doesn't when I just "scan for new content" from the context menu of a show.
In the log it says it is skipping the directories due to no changes, even though I did change them.
I couldn't find a thread to this issue so I created one. Debug log just opening Kodi and having an unsuccessful startup scan is here.
If you think of anything I might've done wrong please tell me, but I didn't change anything from beta2 which worked for me.
Macbook Air 2012, OSX 10.10.1, Kodi 14.beta5
Thank you very much!
Edit: Sorry for misleading, it seems it was OSX's 10.10.1 update that created the bug, I changed the thread title. I really didn't think that it could affect something like the library...
Edit 2: I removed the reference to 10.10.1 again from the title. On the one hand not everyone on 10.10.1 is affected, on the other hand 10.10.2 didn't change anything for me and there is at least one user who seems to have the same issue under windows.
Edit 3: As mkortstiege found out the root of the issue seems to be that OSX's implementation of ExFat doesn't update mtime. Therefore the new fasthash scanning mechanism fails to see that the folders were modified and doesn't pick up new episodes. Workaround and further investigation is in the works. Thank you, mkortstiege!
<advancedsettings>
<videolibrary>
<usefasthash>false</usefasthash>
</videolibrary>
</advancedsettings>
Thank you!
Hello everyone,
