Ever since i updated to Kodi i've been getting these alot where kodi just makes an error and closes like this..
I got some crash logs, but they are pretty small.. Hope someone know whats wrong.
Here is what was in the last 2 crash logs.
xbmc_stacktrace-14.0-RC1 Git_20141130-ea20b83-20141201-143232
Quote:Thread 4008 (process 2696)
# 0 RtlInitUnicodeString
# 1 RtlFreeHeap
# 2 HeapFree
# 3
# 4
# 5
# 6
# 7
# 8
# 9
#12 BaseThreadInitThunk
#13 RtlInitializeExceptionChain
#14 RtlInitializeExceptionChain
Filename : xbmc_crashlog-14.0-RC1 Git_20141130-ea20b83-20141201-143232.dmp (212 KB)
xbmc_crashlog-14.0-RC1 Git_20141130-ea20b83-20141201-143232.dmp - 212 KB
xbmc_stacktrace-14.0-RC1 Git_20141130-ea20b83-20141201-160005
# 1 RtlFreeHeap
# 2 HeapFree
# 3
# 4
# 5
This one is 0 byte and cant upload it.
are you using a skin using skin.widgets? (ie Transparency or Aeon MQ5)
On first boot when upgrading it was Aeon MQ5, but after crashing on first boot i started it up once more and the skin was gone, so i just stuck with confluence, and it's still crashing.
Also i'm not sure that it's the skin that do it anymore, i can reproduce the crash just by open up Kodi and turn the volume up/down using the "Play to xbmc/kodi" addon for google chrome.
Only just started after i updated, and since my controller also is moving to the left by itself after the update, all i got to control my HTPC with atm. is Yatse on my phone, that don't seem to crash it.
Here is another crashlog i made just by changing the volume like i spoke about.
http://xbmclogs.com/show.php?id=360134
Had to Zip
xbmc_crashlog-14.0-RC1 Git_20141130-ea20b83-20141201-223455.dmp
and
xbmc_stacktrace-14.0-RC1 Git_20141130-ea20b83-20141201-223454.txt
since the .DMP is 0 bytes i could not upload it to the site..
XbmcCrash.zip - 514 B
This is from a post i made in this thread thinking it was the same bug, but now im thinking it's not since it's not the skin like they spoke about.
1850654 (post)
The log shows skin widget was loaded even you use confluence. So disable / Remove skin widgets and try again.
(2014-12-08, 17:12)oldpoem Wrote: [ -> ]The log shows skin widget was loaded even you use confluence. So disable / Remove skin widgets and try again.
It worked at first using RC2, but like you can see on my post here it stopped working after i ran SpotiMC, and now it's working once more after i use RC3 that just came out..
My Post
Could you by any chance see something wrong with the controller? It's not working after the upgrade to Kodi from Gotham, it keeps moving left all the time like the stick is hold to the left, and only way to stop it is to unplug the controller (And keep it unplugged). If it's not in there i can make another debug log, or a whole new post about it, since it's not the "kodi stopped working".
EDIT: After i came home i had it happen once more, was watching True Detective and used the Chrome extension to skip back to see what i missed after a call, and when i skipped back i got the "Kodi has stopped working".
Now when i open it up and go to make a debug log, i can skip all i want in it and nothing happens, so at least i can't reproduce it as easy anymore as before.
But it still happens.
Regarding the skins, i got only 2 skins in my active skins, and it's Confluence, and REtouched, i can't seem to disable the REtouched one if thats the one breaking it..
