(2015-02-08, 00:10)senz007 Wrote: [ -> ]hi,
I've installed latest 14.1 into my android device.
I've installed the .zip file from addon-manager, after install it asks me if I want to switch to the new skin, I select yes.
I activate PVR addon, dvb viewer client.
I activate live tv in settings.
The Live-tv option is still not there but if I switch skin to confluence the live TV works fine.
Any ideas?
go to skin settings and activate the live tv home menu button
ahh..thanks! Was a little bit tricky do find it
Hey - Just got this installed tonight on my iPhone 6. I now have the Live TV button. I've found the gear icon inside the Live TV button which lets me switch to Guide and Recordings view. Is there any way to put those as icons on the left as well?
Either way, thanks for this great skin.
(2015-06-16, 05:02)ptaylor Wrote: [ -> ]Hey - Just got this installed tonight on my iPhone 6. I now have the Live TV button. I've found the gear icon inside the Live TV button which lets me switch to Guide and Recordings view. Is there any way to put those as icons on the left as well?
nope, there's no such option.
the buttons on the left are shortcuts to the main categories (movies/music/pictures/etc..),
not to any of the subsections.
Hello,
i have kodi 15.1 on my ipad air2 with pvr / vu+ but i cant show sky tv.
I hear the audio, but no viedeo.
A view german channels (not crypted) can be showed.
Hello. I used re-Touch skin for kodi. This is best skin, imho. But I have some problem. In this skin users can't change current group of tv channels.
All time active only one group that was selected from settings of kodi group manager.
Please add this features for re-Touch skins. Like this work in default skin (confluence) I attached below.
kodi-group,
(2016-01-16, 22:33)Jurik_Phys Wrote: [ -> ]Hello. I used re-Touch skin for kodi. This is best skin, imho. But I have some problem. In this skin users can't change current group of tv channels.
you can click on the 'channels' button to toggle between the channel groups.
(works in confluence as well)
O, realy. This work... but not clearly.
I have three groups: "All channels", "Music TV", "Info TV". "All channels" is first active group. When I click to "Channels" active group changes to next ("Music TV"), second click -> active group changes to "Info TV". But next click to "Channels" don't forward for first group ("All channels"). Loop stops and don't start again before select "All channels" or other group in "Group manager"...
P.S. Works in confluence as well. But in this case this not a problem because confluence have additional menu for manual select active group (
kodi-group-02.png).
P.P.S. I think good idea to add new button for select channels group. For example
kodi-group-03.png.
(2016-01-16, 23:24)Jurik_Phys Wrote: [ -> ]I have three groups: "All channels", "Music TV", "Info TV". "All channels" is first active group. When I click to "Channels" active group changes to next ("Music TV"), second click -> active group changes to "Info TV". But next click to "Channels" don't forward for first group ("All channels"). Loop stops and don't start again before select "All channels" or other group in "Group manager"...
i can't reproduce that.
it loops just fine on my end.
(2016-01-17, 00:44)ronie Wrote: [ -> ]i can't reproduce that.
Thanks for fast reply. I understood that stop of loops is a kodi bug or his thrid party build.
I have kodi 15.2-dmo1+bp2 0 from
http://www.deb-multimedia.org/ jessie-backports/main on debian stable.
ronie Hi -
I'm needing some help getting past the Kodi [not re-touched skin] PVR error and this thread looks like just the place to find a helping bunch of people.
No PVR clients have been started yet
I don't want to post the same thing on multiple BBS so if you could kindly follow this link and reply there I would greatly appreciate it.
On that link you will find my complete hardware & software setup with the
goal of
adding LiveTV to my RaspberryPi w/ Kodi w/ re-Touched skin.
http://forum.kodi.tv/showthread.php?tid=261613
A fellow on that post is saying I need a CableCard receiver seemingly plugged into my home PC [that is running PLEX].
Wow but this is getting complicated to just get LiveTV on my little RaspberryPi.
Thanks again - Jim
