2015-01-18, 21:42
Hey,
I get my Hama sat distributor yesterday and today I tried testing it.
I'm using a two-port DVB Cine S2 DVB-S2.
Before I get the Hama, I just wired the upper port. Everything works fine so war.
Now, I also wired the lower port.
Afterwards I went into TVHeadend WebGUI and enabled the lower port.
I switch to a TV channel, press record. Afterwards I switch to an other TV channel and I could watch TV. WOW! This is working out of the box I thought!
Switched to multiple channels to check if this is working with other channels to. YES, it's working.
Some time later, I switch to the same channel (recording before) and press again record. So far so good.
Then, I tried to switch to another tv channel and get the message "No input detected"
The syslog says the following:
Legend: (unten) is the lower port
I had a look into the TVHeadend WebGUI and saw, that sometimes under status SNR & signal strength show unknown.
Did I need to configure more options or wait until the adapter has did a full scan?
DVB Input config:
http://fs2.directupload.net/images/150118/u4d7kr7e.png
Both adapters have the same setting.
Network is:
http://fs1.directupload.net/images/150118/8li6cm5p.png
I'm using TVHeadend v. 3.9
Thanks in advance for helping.
Quote:Jan 18 20:26:41 xbmc tvheadend[1400]: mpegts: 11420.75H in 19.2E Astra - tuning on STV090x Multistandard : DVB-S #0 (unten)
Jan 18 20:26:41 xbmc tvheadend[1400]: subscription: 0068: "epggrab" subscribing to mux, weight: 3, adapter: "STV090x Multistandard : DVB-S #0 (unten)", network: "19.2E Astra", mux: "11420.75H", hostname: "<N/A>", username: "<N/A>", client: "<N/A>"
Jan 18 20:26:48 xbmc tvheadend[1400]: subscription: 0066: "127.0.0.1 [ alex | XBMC Media Center ]" unsubscribing from "WDR HD Koeln", hostname="127.0.0.1", username="alex", client="XBMC Media Center"
Jan 18 20:26:48 xbmc tvheadend[1400]: mpegts: 10832.25H in 19.2E Astra - tuning on STV090x Multistandard : DVB-S #0 (unten)
Jan 18 20:26:48 xbmc tvheadend[1400]: capmt: CA Client 1: Starting CAPMT server for service "RTL HD" on adapter 0 seq 0x000b
Jan 18 20:26:48 xbmc tvheadend[1400]: subscription: 0069: "127.0.0.1 [ alex | XBMC Media Center ]" subscribing on "RTL HD", weight: 150, adapter: "STV090x Multistandard : DVB-S #0 (unten)", network: "19.2E Astra", mux: "10832.25H", provider: "CBC", service: "RTL HD", hostname="127.0.0.1", username="alex", client="XBMC Media Center"
Jan 18 20:26:48 xbmc tvheadend[1400]: subscription: 0068: "epggrab" unsubscribing
Jan 18 20:26:59 xbmc tvheadend[1400]: capmt: CA Client 1: Removing CAPMT Server from service "RTL HD" on adapter 0
Jan 18 20:27:00 xbmc tvheadend[1400]: mpegts: 11420.75H in 19.2E Astra - tuning on STV090x Multistandard : DVB-S #0 (unten)
Jan 18 20:27:01 xbmc tvheadend[1400]: subscription: 006A: "epggrab" subscribing to mux, weight: 3, adapter: "STV090x Multistandard : DVB-S #0 (unten)", network: "19.2E Astra", mux: "11420.75H", hostname: "<N/A>", username: "<N/A>", client: "<N/A>"
Jan 18 20:27:04 xbmc tvheadend[1400]: subscription: 0069: No input source available for subscription "127.0.0.1 [ alex | XBMC Media Center ]" to channel "RTL HD"
DVB Input config:
Network is:
