Full Version: RPI1-512 Audio Dropout playing HD multichannel music
Pages: 1 2 3 4 5 6
Using the latest firmware and RPi2 OpenELEC build, I still get stuttering when playing multi-channel DSF files unless I force Kodi down to 48.0 KHz audio output. I've also tried "hdmi_mai_thresh=0x1412" and "buffermode=1" but there is no improvement. The problem happens both when playing local files on the MicroSD card as well as remote files from a NFS share. Anything else I should try? Thanks.
Some more info:
config_hdmi_boost=2
hdmi_force_cec_address=65535
hdmi_ignore_cec_init=1
hdmi_mai_thresh=5138
max_usb_current=1
OpenELEC (unofficial) Version: devel-20150417210127-#0417-gacf36ec
OpenELEC git: acf36ec4cb560afa61d02a94c41b54c8a67b5725
OpenELEC:~ # uname -a
Linux OpenELEC 4.0.0 #1 SMP Fri Apr 17 21:02:20 BST 2015 armv7l GNU/Linux
OpenELEC:~ # vcgencmd version
Apr 11 2015 17:37:07
Copyright © 2012 Broadcom
version 311b05fb4e33655a083a6f65b645e6a14e322803 (clean) (release)
OpenELEC:~ # lsb_release
OpenELEC (Milhouse) - Version: devel-20150417210127-#0417-gacf36ec [Build #0417]
OpenELEC:~ # vcdbg log msg 2>&1 | grep DTOK
001369.422: Kernel trailer DTOK property says yes
(2015-04-19, 06:33)PuppetHead Wrote: [ -> ]Using the latest firmware and RPi2 OpenELEC build, I still get stuttering when playing multi-channel DSF files unless I force Kodi down to 48.0 KHz audio output. I've also tried "hdmi_mai_thresh=0x1412" and "buffermode=1" but there is no improvement. The problem happens both when playing local files on the MicroSD card as well as remote files from a NFS share. Anything else I should try? Thanks.
Can you provide a sample file?
Pages: 1 2 3 4 5 6
