Thanks- this is brilliant. Having quick access to CBC and not needing to use the old broken Canada on Demand addon is very welcome. Hopefully this can be maintained more easily.
Is this Gotham only? Thanx.
(2015-03-27, 19:52)nitewing15 Wrote: [ -> ]Is this Gotham only? Thanx.
I just noticed the copy in the kodi.org repo doesn't load for me if this is why you're asking the above. Try loading from my git:
https://github.com/learningit/plugin.video.cbc
I'll try to get the kodi.org issue straightened out soon, I think I screwed up the git pull request
Thanks for this add-on, I can confirm it's working well in Kodi Isengard, downloaded from the Gotham mirrors link in the first post.
This is the best addon!
My son is going to have a giant smile on his face when he sees this tomorrow morning.
The Canada on Demand addon has been getting a little long in the tooth and has been slowly losing shows since it is no longer supported.
Thanks so much.
BTW, installed from the kodi.org repo and working fine from Canada.
(2015-04-03, 08:00)KDMONSTER Wrote: [ -> ]The first link above is broken...updated link is below.
http://mirrors.xbmc.org/addons/gotham/plugin.video.cbc/
The second link (github) above works.
This repo will work with Helix.
There was an issue with the way that the addon was in the kodi.org repo. It has been fixed now, but may cause problems with update processing.
I suggest that you: 1) uninstall the CBC addon; 2) restart kodi; 3) install the CBC addon from the kodi.org repo by going to Settings->Addons->Get Add-ons->Kodi Add-on Repository and selecting CBC addon to install. This will insure that you can get updates correctly for the Kodi.org repo.
This is a great plugin, but I wanted to report one bug.
When I view programs that have more than 15 episodes (Rick Mercer Report - latest season), the older episodes are left out of the list altogether. Same thing with This hour has 22 Minutes..
(2015-04-27, 01:05)advocate99 Wrote: [ -> ]This is a great plugin, but I wanted to report one bug.
Yeah it looks like I forgot to add the next page logic. I'll try to get it in the next update. Thanks.
Just thought I'd leave a message to say 'Thank-You', great add-on.
And thank you for writing the plugin. It's great to be able to watch The National and RMR again.
(2015-04-27, 16:00)learningit Wrote: [ -> ] (2015-04-27, 01:05)advocate99 Wrote: [ -> ]This is a great plugin, but I wanted to report one bug.
Holy crap, I didn't realize that I was throwing away about half the content on the website by not having the next page in place. Thanks!
This should be fixed in V1.0.4 in my git:
https://github.com/learningit/plugin.video.cbc/
Also fixed the double "More Shows".
Let me know if it works. If it works for everyone, I'll put it in the kodi.org repo.
More and Next Page work fine V1.0.4 on Kodi 14.2 T! (win/7/64/)
