2015-04-21, 20:20
I would just like to start by saying thank you to Bignoid for such a great skin.
I've recently migrated my HTPC parts into a Sky HD multiroom box, mainly because of the size of it. After searching around for a skin similar to Sky, I came up short, so I went ahead and started modding for my first time.
Instead of going all out and modding the whole skin, I've only changed the TV guide and infobar when you change channel. If I'm watching TV it looks and feels (kind of) like a Sky box, then when I back out to the Kodi home screen it looks and feels like Kodi again.
Here's where I'm at so far.
I'm trying to get it looking like this below
I've not touched "now, next and channel" views because I don't use them.
Things I need to do:
The number pad
Sidebar
Topbar when you press enter when fullscreen
and maybe some other bits, I can't remember off the top of my head.
The things I want to change but will need some help:
Proper function of the "All Channels" image above the guide, yes this is only a image and it doesn't change if you switch channel group / Possibly add the "actions" options from the epg sidebar.
Change every other row on the epg to a different shade of blue.
Add some sort of progress indicator, ideally shade each tv program which is currently playing.
I will post a download link soon so anyone who's interested can try it out, or maybe give us a hand.
The number pad
Sidebar
