2015-09-10, 01:22
2015-09-12, 21:15
since upgrade to 15.2 the audio is slightly slower than the video.
2015-09-13, 00:40
2015-09-13, 00:41
(2015-09-12, 21:15)DarkAngelHeart Wrote: [ -> ]since upgrade to 15.2 the audio is slightly slower than the video.
Please include details. Read the first post in this thread and include all of that information.
2015-09-15, 11:00
Since the upgrade to 15.2 i get "unable to connect to remote server" when i scan a https remote TV Show library. This happens like 20 times for each scan.
I am getting 429 from the server - so seems we are running into rate limiting. Did you speedup https connections? And if yes - could you wait for 5 Seconds in this case and try again?
Logfile:
http://pastebin.com/dGcvkeY7
Screenshot:
Cheers
Logfile:
Screenshot:
Cheers
2015-09-15, 19:07
(2015-09-15, 11:00)mbosner Wrote: [ -> ]Since the upgrade to 15.2 i get "unable to connect to remote server" when i scan a https remote TV Show library. This happens like 20 times for each scan.
Logfile:
Cheers
Did this also happen on v15.0 or v15.1?
2015-09-16, 01:20
I was on 15.1 and did not run into this problem. But i will test it tomorrow just to be sure.
2015-09-16, 18:25
Is there a chance to test it with kodibuntu ? as i have 15.2 RC1 or 2 on windows and looking good so far.
I saw norwegian subtitles was working now and the kodibuntu is my main moviecentre
2015-09-18, 23:34
Updated first post with new builds
2015-09-19, 09:49
(2015-09-18, 23:34)Martijn Wrote: [ -> ]Updated first post with new builds
Date above the download links needs updating - still says (18 August 2015) but should say (18 September 2015)
2015-09-19, 11:39
2015-09-19, 13:07
(2015-09-18, 23:34)Martijn Wrote: [ -> ]Updated first post with new buildsCan confirm that the rewind now works as expected.
2015-09-19, 14:49
Yes, i can confirm rewind has improved greatly! There's minor b/w artifacts for some seconds after pressing play after rewind. Happens only with H/W acc. on..
Thanks for improving this particular function!
2015-09-19, 15:26
UPNP is working properly again... Thanks team Kodi
2015-09-19, 15:43
thanks for confirming and devs for fixing these problems.
There may just be one fix left and then we can do a full RC2 release and final afterwards
