Full Version: Kodi 15 surround audio stutter after upgrade
hi all,
my system (HTPC) runs Ubuntu 14.04 with PulseAudio disabled, just ALSA in favor of Kodi.
my surround decoder is an AVR, and HTPC is connected to AVR over S/PDIF. sound configuration is passthrough.
above setup has been flawless with Kodi 14, however only passthrough surround audio (DTS or Dolby) started stuttering annoyingly after automatic Isengard upgrade.
i have multichannel music material as WAVE, FLAC, AC3 and DTS audio files. same audio stutter problem occurs.
I re-installed PulseAudio, experimented with different output configurations (fixed/best/optimized) and different sampling rate limits (44.1/48/88.2/96/192), however failed to remove stutter.
stereo sound works perfect.
what should i do? is this a bug to be reported?
For now it's your bug - as you did not provide anything the "Read this before posting" thread wants from you.
sorry for the inconvenience. below are the details;
OS: Ubuntu 14.04.3 64-bit
Kernel Version: 3.13.0-61-generic x86_64
Hardware: CPU is an Intel Haswell with integrated GPU, no external GPU. sound interface is a F/O SPDIF, with the onboard sound chip.
Install Method: PPA
GIT revision: 2f34a0c (Kodi 15)
AV codec and container: A transport stream (TS) file, mediainfo output is as follows.
General
Format : BDAV
Format/Info : Blu-ray Video
File size : 17.1 GiB
Duration : 1h 21mn
Overall bit rate mode : Variable
Overall bit rate : 30.1 Mbps
Maximum Overall bit rate : 48.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : 27
Duration : 1h 21mn
Bit rate mode : Variable
Maximum bit rate : 35.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Scan order : Top Field First
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Menu ID : 1 (0x1)
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Muxing mode : Stream extension
Codec ID : 134
Duration : 1h 21mn
Bit rate : Unknown / 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
audio stutter occurs regardless of being DTS/AC-3/DTS HD-MA/Dolby True HD/hires multich FLAC. i can supply more media info regarding other multichannel files. since there is no crash, i am not providing any debug log.
please click on Debug Log and post this one
Edit: As you are at, I also want: vainfo
Quote: since there is no crash, i am not providing any debug log.
Huh
(2015-08-17, 09:04)David1977 Wrote: [ -> ]
Huh
Yeah :-). Your choice.
well, i checked everything and found that the F/O interconnect faulty. stutter disappeared after replacing the cable.
unfortunately, cable failure coincided with Isengard upgrade. This misled me while troubleshooting.
thank you for your interest. thread may be closed.
