Version 0.9.6 is here!
Its been a long wait, but it has been more work than I would've liked it to be
. But we do have a lot nicer addon now
. It brings a lot of new features & bugfixes. Most importantly; encoding issues are fixed now! Japanese characters are accepted in dirnames etc. The only problem is I can't seem to get japanese characters to work in the frontend of Kodi, but all will still work fine! If you have a configuration with "weird" characters in it, you will notice episodes are now being put into different folders. If it causes problems, please re-scan these shows.
The most important new feature this version brings is the option to update playlists at a specific day and time. You can set this differently for each playlist. See the changelog for all fixes / features.
The next features that are on the list to be included before version 1.0 are (from there we'll hopefully get to v1.1):
- Movie support
- Setting a startpoint for videos to start at from certain channels (to skip annoying standard beginnings)
- Setting an endpoint for videos to end from certain channels (to skip annoying standard endings)
- Donor function. I wanna do something special for my (currently) one and only donor <3 (See the first post if you like to donate, steam games also welcome to relax after this whole coding xD). Every endresult the donor version can do, the free version can to. And always will!
- Translations
- Maybe a community list?
Download Youtube Library v0.9.6
- Uses normal icon/fanart again. (if you liked the newyear art better, you can still find it in the root)
- Added Feature: Only grab the last X videos instead of grabbing all videos from the channel / playlist
- Completely redid the way the service works, making different updating rules for each playlist possible
- Added Feature: Set frequency of updates for each playlist seperately
- Added Feature: Set desired day of the week for the updating of playlists
- Added Feature: Set desired time of the day for the updating of playlists
- Added Feature: song_fallback: video title (original). Just use the original video title as the song title, just as it is on youtube.
- Added Feature: Creates artist.nfo & artwork (unfortunatly kodi does not seem to grab these. Perhaps some skins will)
- Added: You can turn on/off the notify message when a playlist gets updated
- Added: TV Fanart also saved in a subdir called extrafanart
- Added: TV .strm & .nfo files are now stored in subdirectories of their season
- Fixed Bug: Unicode error when playing videos
- Fixed Bug: Unicode file paths (japanese characters etc work)
- Fix: Support for smb:// paths
- Fix: When song_fallback is set to video title / video title (original) & artist_recognisition is set to hardcoded, just those values will be used. No further stripping or altering of the artist / song will be done
- Fix: special://profile is now used (fix for double userdata/userdata included :S)
- Fix: Changed service start from startup to login
- Fix: Since the googleoathclient module is fixed, ytlibrary can depend on that now and loses its own oathclient.
- LOTS of small fixes & little changes
Feedback welcome!
all_users_with_suggestions_and_bugs_before Wrote:.... suggestions & bugs...
All should be fixed now
! And I think even all feature requests are implemented!
(2016-02-25, 06:33)waverz Wrote: [ -> ]Sleuteltje, this is a great add-on! It is exactly what I was looking for.
Is there a way to increase the automatic update frequency or change the time it is set to update?
Thnx
. In v0.9.5, you can change the frequency of how many times the addon updates the playlists in the addon settings (Library settings -> Scan for new Tv Shows / Music Videos every X hours).
In the new v0.9.6 you can even set a specific day of the week and time of day for each playlist seperately
