2015-12-03, 01:32
My youtube addon 5.1.12 does not sort the video dates properly with Kodi 15.2. Previous version 5.1.11 worked fine. Does anyone else have this issue?
(2015-12-03, 01:32)Cal777 Wrote: [ -> ]My youtube addon 5.1.12 does not sort the video dates properly with Kodi 15.2. Previous version 5.1.11 worked fine. Does anyone else have this issue?
(2015-12-03, 09:31)bromix Wrote: [ -> ]5.1.11 version used to have a sort option that was "Year" now it is "Date" with the 12 version. On both my windows 7 machine running 15.2 with Aeon Nox Skin, and RP2 running 14.2 with confluence skin, they will not sort the search by "Date" properly. The videos are not organizing by the dates for ascending or descending. Before the automatic update to 12, a few days ago, it was working fine. I would do a rollback, to see if 12 is the problem, but that option is greyed out.(2015-12-03, 01:32)Cal777 Wrote: [ -> ]My youtube addon 5.1.12 does not sort the video dates properly with Kodi 15.2. Previous version 5.1.11 worked fine. Does anyone else have this issue?
Please use the search and proper forum thread...also provide more details about the problem...maybe a screenshot.
Release - YouTube v5.X.X - KODI 14.X Helix
watch gallery
(2015-12-07, 03:33)DjDiabolik Wrote: [ -> ]Oh wait wait:
I have 5 minutes ago post a similar problems here http://forum.kodi.tv/showthread.php?tid=...pid2180082
All installed on OSMC (kodi 15.2 based i thinks) and latest version of youtube official app
(2015-12-08, 00:42)Cal777 Wrote: [ -> ](2015-12-07, 03:33)DjDiabolik Wrote: [ -> ]Oh wait wait:
Hopefully Bromix can fix the problem with a code tweak.
(2015-12-14, 21:42)Cal777 Wrote: [ -> ](2015-12-08, 00:42)Cal777 Wrote: [ -> ](2015-12-07, 03:33)DjDiabolik Wrote: [ -> ]Oh wait wait:
Conclusion:
The “sort by” filter for the YouTube addon Version 5.1.12 does not work when looking through the results of a search, or previous searches. I tried it in 14.2, 15.2, and Jarvis 16, with different skins. In addition, I used a fresh Kodi download only using the YouTube addon, and it still didn’t work.
There doesn’t seem to be much interest to solve this problem, but here is a workaround:
If you are lucky enough to have used the Backup program addon; restore from a previous backup that has a YouTube version 5.1.11 or older.
Going forward; set your update settings to “never.” That way you can pick and choose which updates you want to install. Once it is running the way you want it to, back it up. That way you only update the addons that have been fully tested, and do not compromise the function of the addon.
If you really need to sort by date, and restore is not an option, then you can just go to a browser and use the YouTube website and filter by upload date, until the newer update fixes the problem.
The addon authors should offer rollbacks of previous stable versions, and offer the newer untested updates more like a beta offering for people to try out. If it is corrupted, then they can rollback to a previous version.
(2015-12-21, 19:07)Cal777 Wrote: [ -> ](2015-12-14, 21:42)Cal777 Wrote: [ -> ](2015-12-08, 00:42)Cal777 Wrote: [ -> ]Hopefully Bromix can fix the problem with a code tweak.
Conclusion:
Update:
Version 5.1.13/14/15 does not fix the sort by "date" setting when searching. Version 15, however, will sort by date when in the "default" sort by setting, but the ascending and descending has no effect.
The author now allows, as of 12/21/15, the rollback option, but only back to version 12, which is where the problem started. Too bad the rollback did not extend to version 11.
(2015-12-25, 19:13)JPXNET Wrote: [ -> ]You quote yourself?
And don't understand a little hint...POST IN HERE:==> http://forum.kodi.tv/showthread.php?tid=200735
