2015-12-19, 15:54
Hi, i'm experiencing a really anoying problem on my windows server 2008 r2 (sp1): When i close Kodi (regular - not killing the process) after 1 - 2 seconds it disappears and it looks like kodi would have been terminated but it is not. It runs in background for about 3 to 5 minutes, then terminates. During that time you even cannot kill the process with task manager!
Kodi Version is 15.2
Fresh Kodi installation
Removed the entire Kodi folder in %appdata% to make sure it doesn't depend on a plugin/addon.
Connection to TV: PC -> Pulse Eight CEC-Adapter -> AVR -> TV
This is the log (%appdata%\Kodi was already rebuild during first executiong for enabling Debug Log) of reproducable process:
1. Starting
2. Waiting for some seconds to completly load and initialize everything (including establishing cec-adapter connection)
2. Closing Kodi
http://www.xbmclogs.com/przngibjz
I already excluded the cec adapter from causing the problemen. Have already disabled it in kodi settings without effect.
There is another peripherial thing recognized by Kodi: imon - but there is no possibility to disably it in the kodi gui
I am using XBMC/Kodi for years on this machine and with this operating system but exiting it took some time (seconds) because auf addons, skints,.. but never took more than 20 sec.
On another machine (Windws 7x64) this problem does not occure.
Help would be gratefully apreceated. Becaus i'm using scripts to do some action after kodi-process is closed. But the most annoying thing is that you have to wait over 3 min before you can start kodi again...
Another thing: For productive purpose i would like to use the skin Aeom MQ 6 containing a lot of plugins. Using this skin in combination wit my mysql database, containing some 1000 of file references, the kodi window most of the time even does not disapper, when i try to close Kodi. During that time i have to wait the full time (more than 3 min) until process is terminated. I'm even not abel to use CTRL+ALT+ENTF or CTRL+SHIFT+ESC to open task manager. The only thing is moving is the regular windows mouse pointer..
1. Starting
2. Closing Kodi
