Hello,
on a fresh Kodi install, with no external addons and nothing going on, i get a 40% CPU usage.
I'd be happy if you could address me to the source of the problem as I am not very experienced to to it myself.
http://xbmclogs.com/pkpqs9kuc
Thank you all!
Nicola
best would be to ssh in and see what's going on there:
maybe it's not kodi.
You can try to disable the rss feeds and see if it helps.
Looks like: Vertical Blank Sync: Let driver decide (restart kodi after setting it) is not set + the rss feed as incubus said.
I did what you advised and from 40% i am at 8% now. Thank yo
Is 8% considered to be normal? If kodi is idle, why in heaven it should use 8% CPU?
before:
http://postimg.org/image/g0g9t2c4d/
after:
http://postimg.org/image/eikh832op/
Another question, from the log:
ERROR: CWinSystemX11::XErrorHandler: BadAtom (invalid Atom parameter), type:0, serial:43, error_code:5, request_code:18 minor_code:0
Should I ignore this or I can do something?
All fine - don't run it under unity / gnome / whatever, no compositing and you can reduce it more.
8% at what clock rate
Percent CPU is a meaningless value without also knowing how much the clock has been idled down (or up).
(2016-01-27, 15:41)MrMC Wrote: [ -> ]8% at what clock rate Percent CPU is a meaningless value without also knowing how much the clock has been idled down (or up).
+1 better find out the current clock and if kodi prevents the cpu from downclocking.
