2016-03-09, 01:33
2016-03-09, 01:41
You get this error while populating sources? Sorry, your screenshot has a too bad resolution (maybe only on my cell phone) to read it.
Also you have to map the sources after populating sources.
2016-03-09, 01:45
Any info in the log file?
2016-03-09, 01:50
Can you please watch my Picture add many Information what I did to make this more Easy for you and me!
Please Help!
There is a Communication Error with the Host! When you click onto Populate Sources.
But if you click onto Connection is Said Connection to Host Succesfully API Jarvis 6.32.
Please Help!
2016-03-09, 13:02
A log file with an exact error make this more easy for you and me...
But anyway, I think your problem is that you don't have set any sources in Kodi.
I've changed the error massage to a better information what the issue exactly is.
2016-03-09, 13:38
(2016-03-09, 13:02)DanCooper Wrote: [ -> ]But anyway, I think your problem is that you don't have set any sources in Kodi.I didn't add this into Sources, must I just add this as External Drive, or must I use the IP Code?
2016-03-09, 13:46
- Set a movie and/or tv show source in Kodi as always
- Click the populate button in Ember KI host settings
- map the Ember sources to the equivalent source in the Kodi column
2016-03-09, 16:20
(2016-03-09, 13:46)DanCooper Wrote: [ -> ]- Set a movie and/or tv show source in Kodi as alwaysSorry can't find it do you maybe have some pictures for me?
2016-03-09, 16:42
2016-03-09, 17:24
(2016-03-09, 16:42)DanCooper Wrote: [ -> ]I hope you know how you have to add e source in Kodi.Finally it works, also I had fixed the Populate Sources error from Ember Media Ember, it's a easy fix:
Just put all the Network Share Settings onto On.
Thank You!, For adding this Nice Function into it.
Just a Question can you please add a Function for the Sets for adding Manuel, Information and Pictures.
Because it doesn't scrape everthing for the Sets, only Cover & Logo.
But No ExtraFanarts / ExtraThumbs / Covers (Including Fake Disc Art) / No NFO MetaInfo.
Even when you add the function into Ember Media Manager, Files and Sources and add the Function for the Artwork, it just doesn't show the artwork.
2016-03-10, 00:34
You maybe missed the same thing as I did?
http://forum.kodi.tv/showthread.php?tid=...pid2271436
