Hi
I am coming from Dvbviewer an are lately testing a lot with Kodi around, since i really like the look of the new 17 versions and with the current alpha 2 i get under 1sec zaptime.
I am having the following Problem.
I have activated Audio passthrough, and it is working for Files.
Playing mkv, i get all modes running DTS,DD,True-HD,DTS-HD......
But if i watch Live Tv with Dvbviewer client i only got 2 channel PCM(for DD 2.0), or Multichannel PCM (for DD5.1).
Maybe someone has a Hint for me.
MFG Alex
What are you expecting? I don't think you will find broadcasters transmitting anything greater than lossy 5.1. Usually ac3.
I expect passthrough if enabled.
If Source is DD5.1 -> passthrough DD5.1 to my AV not PCM .
It's the Kodi 17 alpha
Passtrough in Live TV is not working atm.
(2016-07-30, 13:05)skybird1980 Wrote: [ -> ]It's the Kodi 17 alpha Passtrough in Live TV is not working atm.
This has been done intentional. No passthrough on livestreans
for me it's ok, i have dolby sound even it's just pcm streams^^
(2016-07-30, 14:10)Martijn Wrote: [ -> ] (2016-07-30, 13:05)skybird1980 Wrote: [ -> ]It's the Kodi 17 alpha Passtrough in Live TV is not working atm.
Why?
Thx for this answer, that´s fine for me.
Martijn Can you please elaborate why this has been removed/disabled or point to the PR? I wasn't able to find the commit
for live streams audio speed needs to be adjusted in order to prevent buffers from running dry or overflow. speed for passthrough can't be adjusted, hence no pt for live streams.
Will there be a chance to see pt with live tv/streams again in the near future? Some of my AV-features only work if the decoding is done by the AV-Receiver......(like dynamic range etc.).
many thx
olli
(2016-08-22, 10:28)debutanker Wrote: [ -> ]Will there be a chance to see pt with live tv/streams again in the near future? Some of my AV-features only work if the decoding is done by the AV-Receiver......(like dynamic range etc.).
many thx
olli
Same here, I'm sad to see pt removed for live tv, I love my Dolby Volume stuf etc. on my receiver.
I perfectly understand the distributed clock problem, but I haven't yet seen a TV with integrated tuner or STB that wouldn't do passthrough. If all involved clocks on encoder and decoder side are sufficiently accurate, you won't run into problems for a long time even without synchronization..
