yup, the gitlab one is the official repo.
Hi.
Since I have a problem with FireTV&DTS, I've been asked to provide log.
I tried this add-on, but I get an error sayng that the log file is empty.
http://bayimg.com/JAOoHaaGA
Is there a fix for this?
Did I do anything wrong?
(2020-10-13, 21:21)ronie Wrote: [ -> ]perhaps the logfile is indeed empty?
you can use this method to check the filesize of the logfile (step 1 - 7):
https://kodi.wiki/view/Log_file/File_man...cess#Steps
Thanks for the reply.
If I start playing a movie, then I stop it and try to collect and send log, shuldn't it contain data?
Otherwise when does it get filled?
Tonight I will check the size.
nope, it shouldn't be empty (unless you've disabled logging through the advancedsettings.xml file)... but i have no other idea why the addon would say that the log is empty.
(2018-07-06, 00:03)Karellen Wrote: [ -> ]@tyler Durden
Can you be more specific about how it does not work. I use it and have no problems, and have not seen any other reports on the forum.
What do you want us to do with your logfile?
Upload failed due to unexcepted URL from ubuntu
(2020-10-14, 15:59)ronie Wrote: [ -> ]nope, it shouldn't be empty (unless you've disabled logging through the advancedsettings.xml file)... but i have no other idea why the addon would say that the log is empty.
I got an issue on 19.1 Matrix (LibreElec 9.97.1 RC/Beta). I couldn't upload the logfile to paste.kodi.tv, simply because that gives the error.
I instead made a screenshot with my phone (Hope thats ok?).
https://i.imgur.com/pcsgIbR.jpg
Is this a known issue?
(2021-07-25, 23:16)Converted Wrote: [ -> ]Is this a known issue?
In LibreELEC you can also enter the command
pastekodi
in a terminal session.
Provide the created URL in the forum.
(2021-07-25, 23:19)Klojum Wrote: [ -> ] (2021-07-25, 23:16)Converted Wrote: [ -> ]Is this a known issue?
In LibreELEC you can also enter the command pastekodi
This is the url from the terminal session:
http://ix.io/3u4X
And this is the pastebin url with a copy/paste from the kodi.log:
https://paste.kodi.tv/ajutifuxuy.kodi
(2021-07-25, 23:26)Converted Wrote: [ -> ]And this is the pastebin url with a copy/paste from the kodi.log
I already gave you a reply on the LE forum.
The forum moderators have determined that
banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
(2021-07-25, 23:37)Klojum Wrote: [ -> ] (2021-07-25, 23:26)Converted Wrote: [ -> ]And this is the pastebin url with a copy/paste from the kodi.log
The forum moderators have determined that banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
Sorry for that. Didnt know you were the same person:-)
Freshly installed (LibreElec 19.1 RC 9.97.1 on a Pi4). Same issue. New log:
https://paste.kodi.tv/axuzelurub.kodi and the pastekodi log:
http://ix.io/3u5p
Although LibreELEC also has its own log uploader, the Kodi Log Uploader add-on should work. Perhaps @
ronie can have a look at it.
(2021-07-26, 06:36)Klojum Wrote: [ -> ]Although LibreELEC also has its own log uploader, the Kodi Log Uploader add-on should work. Perhaps @ronie can have a look at it.
Oh they do? Where can i find the libreelec log uploader? Or thats the pastekodi one?
