2021-07-26, 16:05
2021-07-26, 16:42
(2021-07-26, 16:05)ronie Wrote: [ -> ]@Converted could you install this update and let me know if that fixes the issue?Yaj, thanks so much! Its working again:-)
script.module.pyqrcode-1.2.1.2.zip
2021-07-26, 16:48
thx!
2021-07-26, 16:56
(2021-07-26, 16:48)ronie Wrote: [ -> ]thx!
Its going to be in the repo soon? Do i have to install the update again? Or thats not necessary?
2021-07-26, 17:32
Add-ons getting updates should be auto-updated. I'm guessing ronie's file will simply be overwritten with the same version.
2021-07-26, 18:11
it'll be in the repo soon, but since you already have it installed, you won't receive an update
2021-07-26, 18:56
(2021-07-26, 18:11)ronie Wrote: [ -> ]it'll be in the repo soon, but since you already have it installed, you won't receive an update
Okido:-) Thanks so much for resolving so quickly.
2021-09-14, 08:26
After uploading a log, I get the pretty QRCode window and the text including the URL. But I can't select the URL to copy/paste it. Is there a way around this?
STUPID me. I forgot that you can't copy/paste from Kodi gui. Too bad.
I'm trying to get a user to send me a log and I am anticipating his question about sending the URL, which can be a bit tough to read (okay, my glasses Rx is a bit old and it is 1am).
Also, it looks like you have to restart Kodi after installing it before uploading works. A message would be nice for newbies.
I like the addon, but I think it should be very easy for newbies trying to report their first problem to use.After uploading a log, I get the pretty QRCode window and the text including the URL. But I can't select the URL to copy/paste it. Is there a way around this?
2021-09-28, 15:32
@ronie The .zip you linked a few posts earlier did the trick, thank you for that.
But I don't get why there wasn't an automatic download by Kodi (even after checking for updates) for that? Mayber there is a way to spare new users of the addon to go through this process?
2023-01-22, 13:13
Hi
I'm trying to find out why my Android tablet can't play certain files and was advised to load this add-on.
The trouble is that the instructions at https://kodi.wiki/view/Add-on:Kodi_Logfile_Uploader and the OP don't match the UI (Kodi 20.0).
I looked in Program add-ons (blank) and Services with no luck. There doesn't seem to be a search function.
Also could this be loaded by default in order to make diagnosing easier for the user?
E2A: I also tried using Google File Manager app to locate the debug files as per https://kodi.wiki/view/Log_file/Easy but none of those paths are present or contain logs. The irony present in the URL isn't lost on me!
