altered skin, to your taste
still a lot of work, but it works
made only vertical menu
within the image file, how to organize a subject I do not know
Moderator help, place the image from the archive to the topic
install manually
I translated with google
Перевести
скачать скин
download the skin
http://www.fayloobmennik.net/6883177
The download page is in polish
![Sad Sad](https://forum.kodi.tv/images/smilies/frown.png)
I just tried downloading this onto jarvis but it fails to load from zipfile.
haha excuse me for being a dumb arse , have added it manually , works great , just can you confirm where i should put the "new folder " with the bandicam pics in ? i placed it in the userdata folder is that correct please ?
just been looking athe pics in the attached folder and the texts are in polish so i assume i don't need it anyway ?
sorry to ask another question vadim72 , but is there no option to add sub menus ?
(2016-11-18, 17:53)ontap Wrote: [ -> ]sorry to ask another question vadim72 , but is there no option to add sub menus ?
there are settings submenu
settings, Phenomenal, second paragraph from the top, and the bottom line is to add a submenu
I do not know how to add the screenshot, I will review the video and you
When i go to configure main menu items , choose an item the scroll downt to edit submenu , selecting choose item or change action doesn,t do anything , i cannot add any sub menus ?
(2016-11-18, 19:30)ontap Wrote: [ -> ]When i go to configure main menu items , choose an item the scroll downt to edit submenu , selecting choose item or change action doesn,t do anything , i cannot add any sub menus ?
wszystko działa i rozszerzenie
Muszę zrobić film i go obejrzeć i zrozumieć
everything works and extending
I need to make a video and you watch it and understand
(2016-11-18, 19:39)vadim72 Wrote: [ -> ] (2016-11-18, 19:30)ontap Wrote: [ -> ]When i go to configure main menu items , choose an item the scroll downt to edit submenu , selecting choose item or change action doesn,t do anything , i cannot add any sub menus ?
tylko zrobić świeży Kodi dodania swoich danych i konfiguracji podmenu działa dobrze, więc będę usunąć poprzedni build muszę zrobić coś złego, musiałem dodać własne tło twoje są o wiele lepsze, ale tekst na fotki jest w języku polskim, świetny mod dobrze zrobione ,
kocham te czyste światło tła, są one dostępne bez żadnego tekstu na? Nie można ich używać z polskim tekstem.
I thiught i had pasted above comment in both english and polish ?
Was saying i like your clean light backgrounds shame from my point of view that the text on them is in polish
![Smile Smile](https://forum.kodi.tv/images/smilies/smile.png)
I love the fanart on the tv channel view in pvr client , when i switch to guide view it reverts to the default dark basic view , is there a way to get the nice pale bron view as in channels ?
changed my skin on kodi to phenomenal now it gets stuck on the home screen with no icons nothing there just home screen
