Team Kodi are very happy to announce the immediate availability of Kodi 17.0 (Krypton) for Windows, Android, MacOS and iOS. Krypton brings updated default user interfaces, better organisation of settings, and many under-the-hood changes on VideoPlayer, Music Library, PVR, audio on Android, and thousands of small bugfixes and improvements to stability. Note: Kodi 17 downloads will be available in our Ubuntu PPA soon, so stay tuned for updates!
Read more...
Congrats! It seems that the GUI on the RPi2 is noticeably smoother on LE 8. Everything is snappy as can be.
Thanks very much. Great work! Quick question... Has DTS playback been fixed?
Edit: Seems yes it has. Thanks again
DTS playback works in 16.1.
You are already working on Kodi Krypton 17.1 RC1
(2017-02-06, 06:48)Davesummy Wrote: [ -> ]Thanks very much. Great work! Quick question... Has DTS playback been fixed?
I don't think in android DTS playback is supported yet? Pls confirm if u r using it
Sent from my iPhone
I am using Kodibuntu and Kodi 16.1.
I can not be updated (install) 17.0
In repository no new wersion?
root@kodibuntu-zal:~# add-apt-repository ppa:team-xbmc/ppa
OK
root@kodibuntu-zal:~# apt-get update
Reading package lists... Done
root@kodibuntu-zal:~# apt-get upgrade
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@kodibuntu-zal:~# apt-get dist-upgrade
root@kodibuntu-zal:~# kodi -v
16.1 Git:c327c53 Media Center Kodi
Copyright (C) 2005-2013 Team Kodi - http://kodi.tv
root@kodibuntu-zal:~# apt-get install kodi
kodi is already the newest version.
Congratulations on reaching an important milestone!
Android audio will depend how well your firmware supports android standards - and that is not up to Team Kodi.
(2017-02-06, 07:54)IgorA100 Wrote: [ -> ]I am using Kodibuntu and Kodi 16.1.
OK
Click on "Read More" in Post 1.
(2017-02-06, 09:22)nickr Wrote: [ -> ]Click on "Read More" in Post 1.
This?
Quote:Note: Kodi 17 downloads will be available in our Ubuntu PPA soon, so stay tuned for updates!
It is not known when the update will be added?
(2017-02-06, 09:21)nickr Wrote: [ -> ]Android audio will depend how well your firmware supports android standards - and that is not up to Team Kodi.
That would be true if Kodi would support all possible audio paths, including IEC passthrough and OpenSL ES. Is that the case?
I just updated both my Android TV boxes. DTS was fine on both with 16.1 but now one of them won't play DTS which has me stumped. I'm guessing it's a hardware issue. I'm only getting stereo with DTS passthrough switched off and no audio at all when switched on. Android 6 & HDMI.
Edit: Both boxes are only giving me stereo. Back to Jarvis methinks, or are there any plans to fix this issue?
great news, thank you for all [/u]
Good work all, V17 is a HUGE improvement.
