Full Version: Skin Editer
Skin Editor
by Skin Headz
somebody else can pick this up
SCRIPT TO MOVE A SKIN ITEM
PHP Code:
import xbmcgui,sys,os,xbmc
from xml
.etree import ElementTree as et
ACTION_PREVIOUS_MENU
10
ACTION_SELECT_ITEM
7
ACTION_BACKSPACE
92
ACTION_MOVE_RIGHT
2
ACTION_MOVE_LEFT
BAR_FROM_TOP
".//*[@name='SkinHeadzBarTop']/top"
BAR_HEIGHT ".//*[@name='SkinHeadzBarHeight']/height"
BAR_WIDTH ".//*[@name='SkinHeadzBarWidth']/width"
SUB_BAR_TOP ".//*[@name='SkinHeadzSubBarTop']/top"
class WindowXMLDialog(xbmcgui.WindowXMLDialog):
def onInit(self):
#Put list populating code/GUI startup things here
self.window xbmcgui.Window(13000)
self.SkinHeadz xbmc.translatePath('special://skin/1080i/includes_Demon.xml')
self.tree et.parse(self.SkinHeadz)
self.slider self.getControl9119 )
self.sliderperc self.slider.getPercent()
self.refBar self.getControl9120 )
self.text self.getControl9121 )
self.text.setLabel('SET POSITION')
self.refBar.setHeight(int(self.tree.find(".//*[@name='SkinHeadzBarHeight']/height").text))
self.slider.setPercent(self.pixeltopercent(int(self.tree.find('.//top').text)))
self.refBar.setPosition(0,int(self.tree.find('.//top').text))
self.refBar.setWidth(int(self.tree.find(".//*[@name='SkinHeadzBarWidth']/width").text))
def pixeltopercent(self,pixel):
        return
int(pixel 100 1080)
def pixeltopercent1920(self,pixel):
        return
int(pixel 100 1920)
def percenttopixel(self,percent):
        return
int(percent 1080 100)
def percenttopixel920(self,percent):
        return
int(percent 1920 100)
def setHeight(self):
self.currentHeight self.tree.find(BAR_HEIGHT).text
        self
.slider.setPercent(self.pixeltopercent(self.currentHeight))
self.text.setLabel('SET HEIGHT')
self.refBar.setHeight(self.percenttopixel(self.sliderperc))
def setElement(self,percent,element):
        if
element == SUB_BAR_TOP
self.pixels str(int(percent 1080 100))
self.tree.find(element).text self.pixels
            self
.tree.write(self.SkinHeadz)
        else:
            self
        if
element == BAR_FROM_TOP:
self.slider.setPercent(self.pixeltopercent(int(self.tree.find(BAR_HEIGHT).text)))
#elif element == BAR_HEIGHT : xbmc.executebuiltin('ReloadSkin()')
elif element == BAR_HEIGHT:
def bar(self,attrib):
        if
'osition' in attrib:    self.refBar.setPosition(0,self.percenttopixel(self.slider.getPercent()))
elif 'eight' in attribself.refBar.setHeight(self.percenttopixel(self.slider.getPercent()))
def onAction(selfaction):
        if
action == ACTION_BACKSPACE:self.close()
elif action == ACTION_SELECT_ITEM:
            if
"POSITION" in self.text.getLabel():
self.setElement(self.slider.getPercent(),BAR_FROM_TOP)
elif "HEIGHT" in self.text.getLabel():
self.setElement(self.slider.getPercent(),BAR_HEIGHT)
self.setElement(self.slider.getPercent(),SUB_BAR_TOP)
self.text.setLabel('SET WIDTH')
elif "WIDTH" in self.text.getLabel():
self.setElement(self.slider.getPercent(),BAR_WIDTH)
elif action == ACTION_MOVE_LEFT
            if
"POSITION" in self.text.getLabel(): self.bar("position")
elif "HEIGHT" in self.text.getLabel(): self.bar("height")
elif "WIDTH" in self.text.getLabel(): self.bar("width")
elif action == ACTION_MOVE_RIGHT:
            if
def onClick(self,controlID):
        if
controlID == 9119pass
#self.getControl( 9120 ).setPosition(0,int(self.slider.getPercent()))
def onFocus(self,controlID):
pass
if __name__ == "__main__":
scriptDir xbmc.translatePath('special://skin/')
sys.path.insert(0os.path.join(scriptDir,'1080i'))
WindowXMLDialog("Custom_Resize.xml"scriptDir)
w.doModal()
del w
includes_Demon
PHP Code:
<includes>
    <include
name="SkinHeadzBarTop">
top>10</top>
    </include>
    <include
name="SkinHeadzBarHeight">
height>162</height>
    </include>
    <include
name="SkinHeadzSubBarTop">
top>162</top>
    </include>
    <include
name="SkinHeadzBarWidth">
width>2210</width>
    </include>
    <include
name="SkinHeadzSideLeft">
width>750</width>
left>-53</left>
    </include>
    <include
name="SkinHeadzSideRight">
width>750</width>
left>52</left>
    </include>
    <include
name="SkinHeadzSideGap">
itemgap>960</itemgap>
    </include>
includes
Heres the library i used with it
PHP Code:
import xbmc,xbmcaddon,xbmcgui,urllib2,base64,shutil,re,fileinput
import errno
,json,os,hashlib,sys,urllib,xbmcplugin,time
def show
(string):
    return
base64.b64decode(b'%s'%string)
def hide(string):
    return
base64.b64encode(b'%s'%string)
def exe(string):
xbmc.executebuiltin(string)
def updateaddons():
exe('UpdateLocalAddons')
def reloadkeymaps():
exe('Action(reloadkeymaps)')
def window(window):
exe('ActivateWindow(%s)'%window)
def pvr(toggle):
jsonGetPVR '{"jsonrpc":"2.0", "method":"Settings.GetSettingValue", "params":{"setting":"pvrmanager.enabled"}, "id":1}'
jsonSetPVR '{"jsonrpc":"2.0", "method":"Settings.SetSettingValue", "params":{"setting":"pvrmanager.enabled", "value":%s},"id":1}'
jsonNotify '{"jsonrpc":"2.0", "method":"GUI.ShowNotification", "params":{"title":"PVR", "message":"%s","image":""}, "id":1}'
PVR json.loads(xbmc.executeJSONRPC(jsonGetPVR))['result']['value']
    if
toggle:
        if (
PVR == False):
xbmc.executeJSONRPC(jsonSetPVR "true")
xbmc.executeJSONRPC(jsonNotify "Live TV Enabled")
        else:
pass
else:
        if
PVR# i may not want to disable at all. there may be no need
xbmc.executeJSONRPC(jsonSetPVR "false")
xbmc.executeJSONRPC(jsonNotify "Live TV Disabled")
def download(urldestdp None):
    if
not dp:
dp xbmcgui.DialogProgress()
dp.create(addon('id'),"Downloading Content",' '' ')
dp.update(0)
start_time=time.time()
urllib.urlretrieve(urldestlambda nbbsfs_pbhook(nbbsfsdpstart_time))
def _pbhook(numblocksblocksizefilesizedpstart_time):
    try:
percent min(numblocks blocksize 100 filesize100
currently_downloaded float(numblocks) * blocksize / (1024 1024
kbps_speed numblocks blocksize / (time.time() - start_time
        if
kbps_speed and not percent == 100
eta = (filesize numblocks blocksize) / kbps_speed
else:
eta 0
        kbps_speed
kbps_speed 1024
        type_speed
'KB'
if kbps_speed >= 1024:
kbps_speed kbps_speed 1024
            type_speed
'MB'
total float(filesize) / (1024 1024
mbs '[COLOR red][B]Size:[/B] [COLOR green]%.02f[/COLOR] MB of [COLOR green]%.02f[/COLOR] MB[/COLOR]'%(currently_downloadedtotal
e   '[COLOR red][B]Speed:[/B] [COLOR green]%.02f [/COLOR]%s/s ' % (kbps_speedtype_speed)
e  += '[B]ETA:[/B] [COLOR green]%02d:%02d[/COLOR][/COLOR]' divmod(eta60)
dp.update(percent''mbse)
except Exceptione:
        return
str(e)
    if
dp.iscanceled():
dp.close()
sys.exit()
def forceclose(name="This Function"):
    if
choice('In Order To Enable %s, You Must Force Close'%(name),"Force Close","Later"): os._exit(1)
def read(file):
    return
open(file'r').read()
def search(query,file):
    return
re.findall(query,file)
def action(string):
exe('Action(%s)'%(string))
def info(string):
    return
xbmc.getInfoLabel(string)
def refreshContainer():
exe('Container.Refresh')
def updateContainer():
exe('Container.Update')
def startpvr():
exe('StartPVRManager')
def controlMessage(control):
exe('Control.Message(%s)')%(control)
def RunAddon(id):
exe('RunAddon(%s)')%(id)
def RunPlugin(id):
exe('RunPlugin(%s)')%(id)
def condition(string):
    return
xbmc.getCondVisibility(string)
def enableaddon(id,enable='true'):
xbmc.executeJSONRPC('{"jsonrpc": "2.0", "id":1, "method": "Addons.SetAddonEnabled", "params": { "addonid": "%s", "enabled": "%s" }}'%(id,enable))
def hasaddon(addon):
    try:
        if
xbmcaddon.Addon(addon): return True
    except
: return False
def copy
(srcdst):
    try:
shutil.copytree(srcdst)
except OSError as exc# python >2.5
if exc.errno == errno.ENOTDIR:
shutil.copy(srcdst)
        else:
raise
def addon
(item,id="skin.aeon.nox.silvo.skinheadz"):
    try:
        if
item     == 'id'                : return xbmcaddon.Addon(id).getAddonInfo('id')
elif item    == 'name'            : return xbmcaddon.Addon(id).getAddonInfo('name')
elif item     == 'path'            : return xbmcaddon.Addon(id).getAddonInfo('path')
elif item     == 'icon'            : return xbmcaddon.Addon(id).getAddonInfo('icon')
elif item     == 'fanart'            : return xbmcaddon.Addon(id).getAddonInfo('fanart')
elif item     == 'author'            : return xbmcaddon.Addon(id).getAddonInfo('author')
elif item     == 'version'        : return xbmcaddon.Addon(id).getAddonInfo('version')
elif item     == 'summary'        : return xbmcaddon.Addon(id).getAddonInfo('summary')
elif item     == 'description'    : return xbmcaddon.Addon(id).getAddonInfo('description')
except: return False
def data
(string):
    return
json.loads(string)
def openURL(url):
req urllib2.Request(url)
req.add_header('User-Agent'addon('id'))
response urllib2.urlopen(req)
link=response.read()
response.close()
    return
link
def notification
(message,title=addon('name')):
xbmcgui.Dialog().notification(title,message)
def ok(line1,line2=None,line3=None,title=addon('name')):
xbmcgui.Dialog().ok(titleline1=line1,line2=line2,line3=line3)
def choice(string,y='YES',n='NO',title=addon('name')):
    return
xbmcgui.Dialog().yesno(title,string,yeslabel=y,nolabel=n)
def input(heading=addon('name')):
    return
xbmcgui.Dialog().input(headingtype=xbmcgui.INPUT_ALPHANUM)
def cut(string):
exec(string)
def log(string):
xbmc.log(string)
def setting(id,value=None,addon=addon('id')):
    if
not value                     : return xbmcaddon.Addon(addon).getSetting(id)
    else                             : return
xbmcaddon.Addon(addon).setSetting(id,value)
def insertline(file,search,add):
includes = []
    for
line in fileinput.FileInput(file,inplace=1):
        if
search in line:
line=line.replace(line,line+add)
includes.append(line)
with open(file"a") as myfile:
        for
line in includes:
myfile.write(line)
def md5(fname):
hash_md5 hashlib.md5()
with open(fname"rb") as f:
        for
chunk in iter(lambdaf.read(4096), b""):
hash_md5.update(chunk)
    return
hash_md5.hexdigest()
def addItemGUI(conrol,label1=None,label2=None,icon=None,thumb=None):
self.self.window.getControl(control).addItem(xbmcgui.ListItem(label1label2=urliconImage=iconthumbnailImage=thumb))
def addDir(displaymode=None,username=None,password=None,icon=addon(show('aWNvbg==')),description=addon(show('aWQ='))):
sys.argv[0]
    if
not mode == None:         += show("P21vZGU9JXM=") % urllib.quote_plus(mode)
ok=True
    liz
=xbmcgui.ListItem(displayiconImage=show("RGVmYXVsdEZvbGRlci5wbmc="), thumbnailImage=icon)
liz.setInfotype="Video"infoLabels={ show("VGl0bGU="): displayshow("UGxvdA=="): description} )
ok=xbmcplugin.addDirectoryItem(handle=int(sys.argv[1]),url=u,listitem=liz,isFolder=True)
    return
ok
def addItem
sys.argv[0]
    if
ok=True
    liz
ok=xbmcplugin.addDirectoryItem(handle=int(sys.argv[1]),url=u,listitem=liz)
    return
ok
def skinres
results search(r'aspect="(.+?)" .+? folder="(.+?)"',read(xbmc.translatePath('special://skin/addon.xml')))
    for
item in results:
        if
info('Skin.AspectRatio'in item:
            for
listitem in item:
                if
not info('Skin.AspectRatio'in listitem:
xbmc.log(listitem)
                    return
listitem
def get
(path,file=None):
    if
'ystem'         in path:                         return xbmc.translatePath('special://xbmc/'+file)                                     if file else xbmc.translatePath('special://xbmc/')
elif 'ome'         in path:                          return xbmc.translatePath('special://home/'+file)                                     if file else xbmc.translatePath('special://home/')
elif 'ddons'     in path:                         return xbmc.translatePath('special://home/addons/'+file)                             if file else xbmc.translatePath('special://home/addons/')
elif 'serdata'     in path:                         return xbmc.translatePath('special://userdata/'+file)                                 if file else xbmc.translatePath('special://userdata/')
elif 'atabase'     in path:                         return xbmc.translatePath('special://userdata/Database/'+file)                         if file else xbmc.translatePath('special://userdata/Database/')
elif 'eymaps'     in path:                         return xbmc.translatePath('special://userdata/keymaps/'+file)                         if file else xbmc.translatePath('special://userdata/keymaps/')
elif 'ddon'     in path and 'ata' in path:         return xbmc.translatePath('special://userdata/addon_data/'+file)                     if file else xbmc.translatePath('special://userdata/addon_data')
elif 'lugin.'     in path:                         return xbmc.translatePath('special://home/addons/'+path+"/"+file)                     if file else xbmc.translatePath('special://home/addons/%s/'%path)
elif 'cript.'     in path:                         return xbmc.translatePath('special://home/addons/'+path+"/"+file)                     if file else xbmc.translatePath('special://home/addons/%s/'%path)
elif 'kin'         in path and 'addon.xml' in file:return xbmc.translatePath('special://skin/%s'%(file))
elif 'kin'         in path and 'debug' in file:     return xbmc.translatePath('special://skin/media/%s'%(file))
elif 'kin'         in path:                        return xbmc.translatePath('special://skin/%s/%s'%(skinres(),file))                  if file else xbmc.translatePath('special://skin/'
just activate the home window before you runscript and if your trying to do this from android for any odd reason, youll need to impliment the python 2.7 version of elementtree
hope somebody elses imagination is intrigued
Just a few questions... Where is all the code to move the now playing widgets if you position the main menu over their current position? What about the two widget options offered and how to handle where they go when moving the menu bar to all those different possible locations?
(2017-02-27, 09:08)mikeSiLVO Wrote: [ -> ]Just a few questions... Where is all the code to move the now playing widgets if you position the main menu over their current position? What about the two widget options offered and how to handle where they go when moving the menu bar to all those different possible locations?
well to be honest i never finished it,in the version i was editing, i was going to manually add in my own widgets. i ended up adding quite a few things to it like background panel images added more things to color, changeable logo, sidefade, and even adjusting them. i tried to make is as customizable as possible. i even added an intro video with an overlay logo that fades in so the user could just place theirs inside. was going to be great but i'm just too busy
if you need any help integrating it, i'll be here
bump
