Hi Gade,
If you play a file inside of the DB for some minutes you can see that you played the file before.
if the file is not inside the db you can continue the file, but you can't see it.
Maybe it's possible to update the status icon?
I will post a Screenshot what i mean.
https://abload.de/img/screenshot001fsboa.png
Beside it seams possible (in Confluence e.g.)
Hi skybird.
Thanks a lot for reporting the issue.
I think I found the reason for this and have fixed it and several other related issues.
It will be fixed in the next development update.
Please let me know wheather it's fixed or not.
I just pushed version 10.4.4 to my development repo, which should fix the issue.
Thank you so much :') when it will be added to kodi main
repository?
hehe, thanks
I allready have your dev repo. the bug/request is from one of our community member at kodinerds.net and i doesn't want to explain how he can install it.
he even can't read english. But ok i will explain it to him now.
It would be nice to test if the issue is solved.
it is
i allready did-
Perfect, thanks for the fast reply.
I'll mark this thread as solved.
the community member answered me and told me to give big thanks back to you.
the problem is now that the icon is just too small if you are far away from tv.
Maybe it's possible to add another viewtype with bigger icons for the Filetype?
Glad it's working.
I'm already adding some new views for video content.
The bug is back with 10.4.5 ^^;
The Icon is not beeing marked as "half seen" or something.
If it worked in 10.4.4, it's going to work in 10.4.5.
Nothing has been changed between those two versions.
Let me see a screenshot.
no need to lie for me
https://youtu.be/XR8n1NMTkkg
however i checked the bugfix after you told it was fixed in dev repo and it was ok. so something changed.
What?!??
Nothing in the files at all has changed from 10.4.4 to 10.4.5 in that area. So if it worked in 10.4.4, it'll work in 10.4.5.
Try installing the versions from zip:
Here's 10.4.4 that you told me was fixing the issues.
Here's the recent 10.4.5
I bet that the folder you're showing me is treated as tv shows. And the folder you were testing with 10.4.4 is being treated as episodes.
You need to test with the exact same folder as before.
