Hello Kodi People. First off, I do like Kodi very much. Secondly...however, it will not open. As previous comments have stated, the new version notification came up when I opened the older version, so I followed the prompts and downloaded the new version aaaaand bupkiss. I uninstalled kodi, waited then redownloaded again, restarted computer aaaaand still bupkiss... Am at a loss as to what to do...
I'm having three same problem. I have version 16 jarvis and was told to upgrade and it will just overwrite with version 17.1 krypton. Well it will either not launch or says error. I have also Uninstalled and restarted my computer with no luck launching the new version. Would veery much like some help. Kodi is just an awesome program and would love to keep using it. Thanks guys
Hello Love-Arlie,
What operating system are you using.
Which site did you download Kodi from
I'm also having the same issues. Installation process appears to OK, however unable to open Kodi 17.1. My operating system is windows 10 and I downloaded from the official Kodi Site. Been using Kodi for a number of years and I think it is awesome
You dopey support guys need to learn to read. It does bupkiss and then it will not launch or says error. Please fix this. I have paid nothing for this software and I demand it.
Open Explorer in Windows (Windowskey + E) and paste in %AppData%\Kodi\userdata\Database in the top field.
Find the file called Addons27.db and delete it.
This file sometimes cause this issue.
Deleting Addnons27.db as described above worked for me. Thanks for the help.
Hey all, I have been all over the forums since yesterday, I have deleted the addons27 as suggested but now i am getting an error stating "unable to create application" when the installation wizard is finished. I am running windows 10 and was upgrading from Jarvis 16.2 to krypton 17.1, i have also completed all windows updates as others have suggested and i still cannot open kodi, can someone provide any further assistance? do not have debug log as have not been able to get into kodi.
file:///C:/Users/Ashley/OneDrive/Pictures/Screenshots/2017-04-04%20(2).png
Hope i used pastebin correctly? its my first time using it.
Debug log (wiki) also gets created if Kodi crashes at starting.
Open %AppData%\Kodi\ in Windows Explorer, then open kodi.log, paste the content at
https://pastebin.com/ and then post the link you get here.
file:///C:/Users/Ashley/OneDrive/Pictures/Screenshots/2017-04-05.png
(2017-04-05, 13:34)AshMcG Wrote: [ -> ]file:///C:/Users/Ashley/OneDrive/Pictures/Screenshots/2017-04-05.png
This is only accessible on your computer.
You need to upload the pictures somewhere (eg
https://imgbb.com/) and post the link you get here.
