Hello. Skin has a bug recently on my Krypton 17 / amazon Fire TV. Cannot move cursor left/right on any screen. Only up/down. Anyone saw this as well?
Hi doctorf72 and welcome to the forums.
I need a lot more info than that.
Where exactly doesn't navigation work for you?
Which version of Rapier do you use?
Do you use a mod or build?
Thank you, Gade.
Here are details:
HW: Amazon Fire TV
Kodi: v17.1 Krypton
Skin: Rapier 10.5.0
path to screen:
Add-Ons->Add On Browser-->Install from Repository-->Any Repo-->Add On Install
On this screen top buttons row : CONFIGURE INSTALL ENABLE RUN UPDATE is completely disabled - no active button at all.
It used to work couple of days before, but now no option to install/remove/update any add on
On other skins it works fine, but i do more like Rapier, this is a reason i am writing here. Like this skin much.
Any idea what might happen? What else to check? Maybe any settings?
Thank you in advance.
Thanks for the details and thanks a lot for the kind words.
Sounds like you have enabled Kiosk Mode: Skin Settings > General > Enable Kiosk Mode (DISABLE this setting)
Can you please check this?
WORKS PERFEEEEEEECT!!!!!!!!!!!!!
Thank you a lot.
Appreciate your help.
My personal opinion this is best skin i used.
Thank you a lot again.
Glad you got it solved.
And thanks again for the kind words - I really appreciate it.
Let me know if you have any questions.
I'll mark this thread as solved.
