Full Version: Some Live TV Channels Not Working
Have a Windows 10 machine using Kodi 17.3 with NextPVR as the PVR. Have a Ceton quad tuner for the HD TV. Everything is working really well except that a few channels do not work in Live TV mode. I can record from these channels and playback is flawless when watching these recordings. These channels come in fine when using the NextPVR either directly or through the localhost browser interface.
Anyone know a fix for the few channels not playing live in Kodi?
You'd probably need to post the kodi.log, with debug logging enabled, showing an attempt to view one of these channels, so one of the kodi experters can tell us what Kodi is unhappy about.
BTW just tried X NEWA (it is a program addon, not a PVR addon) as a NextPVR alternate. They both use Next PVR backend. X NEWA works so maybe the issue is the NextPVR plugin settings?
Who knows - maybe the logs will tell us.
Fixed the issue with a full removal and clean reinstall of Kodi. Apologies for not posting the logs, I'll need to look into how to do that for next time. Thanks for your assistance.
I'm not the OP, but I have a similar problem, one channel that will not play Live TV regardless of client (I've tried 2-3 different PCs), but does work in NEWA.
01:40:24.822 T:7844   DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
01:40:24.854 T:7844   DEBUG: Loading settings for pvr://channels/tv/All channels/pvr.nextpvr_7240.pvr
01:40:24.891 T:7844   DEBUG: Radio UECP (RDS) Processor - new CDVDRadioRDSData::CDVDRadioRDSData
01:40:24.891 T:7844  NOTICE: VideoPlayer: Opening: pvr://channels/tv/All channels/pvr.nextpvr_7240.pvr
01:40:24.891 T:7844 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
01:40:24.895 T:6620   DEBUG: Thread VideoPlayer start, auto delete: false
01:40:24.895 T:6620  NOTICE: Creating InputStream
01:40:24.896 T:6620   DEBUG: PVRManager - PVR::CPVRManager::OpenLiveStream - opening live stream on channel 'DKCPQ'
01:40:24.896 T:6620   DEBUG: opening live stream for channel 'DKCPQ'
01:40:24.896 T:6620   DEBUG: AddOnLog: NextPVR PVR Client: OpenLiveStream(113:DKCPQ) (oid=7240)
01:40:24.899 T:6620   DEBUG: AddOnLog: NextPVR PVR Client: OpenLiveStream()@1
01:40:25.396 T:7844   DEBUG: ------ Window Init (DialogBusy.xml) ------
01:40:29.772 T:7844   DEBUG: Keyboard: scancode: 0x5b, sym: 0x0137, unicode: 0x0000, modifier: 0x10
01:40:29.772 T:7844   DEBUG: CInputManager::OnKey: win-leftwindows (0x10f0d6) pressed, action is
01:40:29.971 T:7844   DEBUG: CWinEventsWin32::WndProcWindow is active
01:40:29.972 T:7844   DEBUG: CWinEventsWin32::WndProc: Focus switched to process C:\Windows\explorer.exe
01:40:32.822 T:6620   DEBUG: AddOnLog: NextPVR PVR Client: OpenLiveStream()@2
01:40:32.822 T:6620   DEBUG: AddOnLog: NextPVR PVR Client: HTTP/1.1 200 OK
                                            Server: NextPVR
                                            Connection: Close
                                            Content-Range: *
                                            Content-Type: video/MP2T
01:40:32.827 T:6620   DEBUG: AddOnLog: NextPVR PVR Client: OpenLiveStream()@exit
01:40:32.913 T:6620   DEBUG: CDVDInputStreamPVRManager - CDVDInputStreamPVRManager::Open - playback has started on filename pvr://channels/tv/All channels/pvr.nextpvr_7240.pvr
01:40:32.913 T:6620   DEBUG: CDVDInputStreamPVRManager::Open - stream opened: pvr://channels/tv/All channels/pvr.nextpvr_7240.pvr
01:40:32.913 T:6620  NOTICE: Creating Demuxer
01:40:33.574 T:7844    INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://image.tmdb.org (easy=0C149020, multi=0C223288)
01:40:33.575 T:7844    INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://image.tmdb.org (easy=0D491FB8, multi=0C2246D8)
01:40:33.575 T:7844    INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://image.tmdb.org (easy=0DBD2020, multi=0C224160)
01:40:34.089 T:7844    INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://image.tmdb.org (easy=0C0B2E98, multi=0C223B20)
01:40:34.608 T:7844    INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://d3gtl9l2a4fn1j.cloudfront.net (easy=0D470020, multi=00000000)
01:40:35.816 T:6620    INFO: ffmpeg[19DC]: Input #0, mpegts, pvr://channels/tv/All channels/pvr.nextpvr_7240.pv':
01:40:35.816 T:6620    INFO: ffmpeg[19DC]:   Duration: N/A, bitrate: N/A
01:40:35.816 T:6620    INFO: ffmpeg[19DC]:   Program 1
01:40:35.816 T:6620   DEBUG: CApplication::OnPlayBackStarted: play state was 1, starting 1
01:40:35.816 T:6620   DEBUG: CVideoPlayer::SetCaching - caching state 2
01:40:35.816 T:6620   DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
01:40:35.821 T:7844   DEBUG: CApplication::PlayFile: OpenFile succeed, play state 2
01:40:35.821 T:7844   DEBUG: CApplication::OnPlayBackStarted: play state was 2, starting 0
01:40:35.821 T:7844   DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
01:40:35.835 T:6620   DEBUG: CDVDDemuxFFmpeg::Read() fetching extradata, extradata_size(34)
01:40:35.837 T:6116   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
01:40:35.838 T:6116   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
01:40:35.838 T:7844   DEBUG: CDirectoryProvider[pvr://channels/tv/*?view=lastplayed]: refreshing..
01:40:35.838 T:7992   DEBUG: CGUIInfoManager::SetCurrentMovie(pvr://channels/tv/All channels/pvr.nextpvr_7240.pvr)
01:40:35.845 T:11504   DEBUG: CPVRDirectory::GetDirectory(pvr://channels/tv/*?view=lastplayed)
01:40:36.060 T:7844   DEBUG: ------ Window Deinit (DialogBusy.xml) ------
01:40:39.057 T:7844   DEBUG: CWinEventsWin32::WndProcWindow is active
01:40:39.122 T:7844   DEBUG: Keyboard: scancode: 0x0f, sym: 0x0009, unicode: 0x0000, modifier: 0x0
01:40:40.588 T:7844   DEBUG: Keyboard: scancode: 0x38, sym: 0x0134, unicode: 0x0000, modifier: 0x100
01:40:40.588 T:7844   DEBUG: CInputManager::OnKey: alt-leftalt (0x4f0d4) pressed, action is
01:40:41.062 T:7844   DEBUG: CWinEventsWin32::WndProcWindow is active
01:40:41.064 T:7844   DEBUG: CWinEventsWin32::WndProc: Focus switched to process C:\Windows\explorer.exe
01:40:44.457 T:7844   DEBUG: CWinEventsWin32::WndProcWindow is active
01:40:44.489 T:7844   DEBUG: Keyboard: scancode: 0x0f, sym: 0x0009, unicode: 0x0000, modifier: 0x0
01:40:49.257 T:7844   DEBUG: ------ Window Init (Pointer.xml) ------
01:40:52.505 T:7844    INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://thetvdb.com (easy=0C342020, multi=116CA780)
01:40:52.506 T:7844    INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://thetvdb.com (easy=0C0A3020, multi=116CB8B0)
01:40:52.507 T:7844    INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://htpc (easy=1D031030, multi=00000000)
01:40:52.538 T:7844   DEBUG: Keyboard: scancode: 0x2d, sym: 0x0078, unicode: 0x0078, modifier: 0x0
01:40:52.538 T:7844   DEBUG: CInputManager::OnKey: x (0xf058) pressed, action is Stop
01:40:52.539 T:7844  NOTICE: CVideoPlayer::CloseFile()
01:40:52.539 T:7844  NOTICE: VideoPlayer: waiting for threads to exit
01:40:52.594 T:6620  NOTICE: CVideoPlayer::OnExit()
01:40:52.595 T:6620   DEBUG: CVideoPlayer::SetCaching - caching state 0
01:40:52.595 T:6620   DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
01:40:52.697 T:6620   DEBUG: AddOnLog: NextPVR PVR Client: CloseLiveStream
01:40:52.697 T:11504   DEBUG: CSaveFileStateJob::DoWork - Saving file state for video item pvr://channels/tv/All channels/pvr.nextpvr_7240.pvr
01:40:52.697 T:6620   DEBUG: AddOnLog: NextPVR PVR Client: Telling backend of live session closure
01:40:52.697 T:6620   DEBUG: CFileCache::Open - opening <service> using cache
01:40:52.702 T:6620   DEBUG: CurlFile::Open(1A543020) http://htpc:8866/service?method=channel.stop&sid=17abc388fcc04c83a95c56399809441a
01:40:52.731 T:11504   DEBUG: Mysql execute: update settings set Deinterlace=32,ViewMode=0,ZoomAmount=1.000000,PixelRatio=1.000000,VerticalShift=0.000000,AudioStream=-1,SubtitleStream=-1,SubtitleDelay=0.000000,SubtitlesOn=1,Brightness=50.000000,Contrast=50.000000,Gamma=20.000000,VolumeAmplification=0.000000,AudioDelay=0.000000,OutputToAllSpeakers=0,Sharpness=0.000000,NoiseReduction=0.000000,NonLinStretch=0,PostProcess=0,ScalingMethod=13,ResumeTime=0,StereoMode=0,StereoInvert=0, VideoStream=-1 where idFile=3816
01:40:52.759 T:5860   DEBUG: Thread FileCache start, auto delete: false
01:40:52.759 T:5860    INFO: CFileCache::Process - Source read didn't return any data! Hit eof(?)
01:40:52.809 T:5860   DEBUG: Thread FileCache 5860 terminating
01:40:52.812 T:6620   DEBUG: AddOnLog: NextPVR PVR Client: CloseLiveStream@exit
01:40:52.812 T:6620   DEBUG: CDVDInputStreamPVRManager::Close - stream closed
01:40:52.812 T:6620   DEBUG: CApplication::OnPlayBackStopped: play state was 2, starting 0
01:40:52.812 T:6116   DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
01:40:52.812 T:7844  NOTICE: VideoPlayer: finished waiting
01:40:52.813 T:6620   DEBUG: Thread VideoPlayer 6620 terminating
01:40:52.813 T:7844   DEBUG: CRenderManager::DeleteRenderer - deleting renderer
01:40:52.813 T:6116   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
I think that's the relevant debug log, from pressing enter to play the channel to pressing x to stop playback. For what it's worth, I'm using a Ceton Infnitv 6 PCIe on Windows 10, and this playback attempt was from a different Windows 10 machine running the Windows Store build of Kodi.[/code]
