Full Version: Live TV buffering issues
Hi
Just wanted to say that i love the Titan skin and thank you to all who have supported its development.
Ive got this strange thing happening using PVR and the Titan skin. Since a recent update (im not sure which TBH) if i select a channel from the EPG the channel loads but then kind of does this weird buffereing thing before it settles out and plays live TV fine.
This only happens when i am using Titan skin. Ive tried it on other skins and have no issues. If im watching a TV channel and i select 'back' so the OSD shows - the small box to right showing live TV in the OSD does this weird cycling / buffering thing aswell for a a few seconds before it settles out?
I have latest version of Titan running on Kodi Android 17.3.
Im pretty sure this is skin related. I ran Estuary skin and went crazy selecting TV, going back, pausing, bringing up the menu...etc multiple times and works with no issues.
Any help appreciated.
(2017-05-30, 17:08)neild7744 Wrote: [ -> ]Hi
Hi.
Any news on this? Did you managed to get a fix? It seems that i am having the same issue on my LibreElec 8.1.2 with Kodi Krypton...
(2017-10-17, 16:50)paulsobral Wrote: [ -> ]
Hi.
Same issue here, I am on DVBViewer PVR, Libreelec 8.2, changing channel buff a lot in Titan, but when I change to confluence to see the result it appear to be fine, similar to loading movies and Tv shows it become slow recently, it has bee discussed somewhere I can't recalled that the skink helper could have been the cause.
