I have a new 55 inch Spectrum TV and Kodi has been working fantastic. Today I turned it on and was seeing the same picture on each side on the TV. Like I was seeing double. Can someone help me fix this? I tried it in my bed rooms 36" and it works ok there. Now it doesn't work there anymore. Probably from me messing around with it. Can some one help me with this issue? I wanted to reset but don't want to loose all the settings because it was done for me by a friend of my daughters.... THANKS Confused
Jagstarrr~
Navigate to the following :
Settings>System Settings>Display
Look for the setting:
Stereoscopic 3D mode/Current
Set it to Disabled
(2017-06-18, 04:46)Karellen Wrote: [ -> ]Navigate to the following :
Set it to Disabled
just to add ... you won't see that setting if your
Settings Level (at the bottom of screen) is
Basic or
Standard
you need to select
Settings Level "Advanced" or "Expert" to see the Stereoscopic 3D mode setting.
Quote:Now it doesn't work there anymore. Probably from me messing around with it.
Oops went from bad to worse, get the milk & cookies out... you'll need that friend of your daughter.
