Hi I have a Pi3 running Stretch and kodi 17.4.
It is currently crashing frequently (usually when sat idle).
I have posted latest crash log here-->
https://pastebin.com/64D4pR7u
I have updated multiple times update/upgrade/dist-upgrade and rpi-update
And its crashed again while typing this
Error on command line is AccessInit: hash collision: 22 for both 1 and 1
Segmentation fault (core dumped)
Crash report available at /home/........... etc
Anyone got any suggestions?
I have no immediate solution for your crash problems.
Just wondering:
* Do you really need a full Debian OS on your RPi3, because there are smaller and more stable alternatives.
* Who does your filenaming? It's a bit ... enthousiastic, to say the least
/2 - TV/Nurse Jackie/Nurse Jackie Season 6/Nurse Jackie S06E12 720p HDTV x264 [MKV,AC3,5.1] Ehhhh/Nurse Jackie S06E12 - Flight - Ehhhh.mkv
I have disabled weather, and will give that a spin. Thank you, if it still goes on I will post the debug logs too
(2017-09-13, 14:25)rascas Wrote: [ -> ]Please post a debug log:
http://kodi.wiki/view/Log_file
The error seems related to python, can you disable the weather addon and test again?
Its Raspbian Stretch, not the full one
and file names etc, just how it was saved, I didnt rename them
Q.
(2017-09-13, 13:07)Klojum Wrote: [ -> ]I have no immediate solution for your crash problems.
Just wondering:
"AccessInit: hash collision:" seems to be a python error, so I'd be thinking add-ons.
Can you try renaming .kodi (e.g. to .kodi_back) and starting kodi?
This will start with default settings and no add-ons. Does it crash when sat idle?
If not then set up your usual settings and sources. Still okay?
Only now install add-ons one at a time and check if problem occurs.
