Full Version: Trying to match kodi genre with mythtv categories
Running: mythtv 0.28, kodi 17.4
After reading the main thread I tried copying /usr/share/kodi/addons/pvr.mythtv/resources/eit_categories.txt to /home/derek/.kodi/userdata/addon_data/pvr.mythtv/eit_categories.txt
with the thought that updating this would fix the genres not matching the categories.
For example:
mysql> select category,title,category_type from program where title like '%Machine%';
| category | title | category_type |
| Action | Terminator 3: Rise Of The Machines | movie |
1 row in set (0.02 sec)
In the kodi epg it is listed as genre : Adventure/Western/War but eit_categories.txt has only 0x12;"Movie - Adventure/Western/War"
The movie part does not show
0x12 also has Adventure, Action, Western, War
I tried creating 0x12;"Movie - Action" in the userdata copy of eit_categories.txt and cycling Kodi, but it made no difference
Is anyone able to give instructions on how to do this one, after which I should be able to fix others (especially the "Other / Unknown" genre
Thanks Derek
(2017-10-22, 03:31)glubbish Wrote: [ -> ]Running: mythtv 0.28, kodi 17.4
For example:
Thanks Derek
Hi Derek. The eit categories file allows you to match the Kodi code i.e 0x12 with one or more category name provided by your backend. For you case I guess you have to add line (or update one unused line 0x12) to match with "Action" as follow:
0x12;"Action"
You can add more lines to match 0x12 with others backend categories.
Hi Janbar,
eit_categories.txt already has:
0x12;"Action"
The genre in the mythtv epg shows : Adventure/Western/War
Thanks Derek
That's right: the epg code 0x12 is "Adventure/Western/war". Probably you want to match "Action" to an other epg code. So you have to choose the one you want.
Hi Janbar,
Still cant work this out.
mysql> select category,title,category_type,seriesid,programid,manualid,generic,listingsource from program where title like '%Dive%';
| category | title     | category_type | seriesid  | programid   | manualid | generic | listingsource |
| Action   | Divergent | movie         | 214470996 | MV214470996 |        0 |       0 |             4 |
1 row in set (0.03 sec)
Looked at https://www.etsi.org/deliver/etsi_en/300...11101p.pdf (page 40) and see:
0x1 0x0 movie/drama (general)
0x1 0x1 detective/thriller
0x1 0x2 adventure/western/war
0x1 0x3 science fiction/fantasy/horror
0x1 0x4 comedy
0x1 0x5 soap/melodrama/folkloric
0x1 0x6 romance
0x1 0x7 serious/classical/religious/historical movie/drama
0x1 0x8 adult movie/drama
0x1 0x9 to 0xE Reserved for future use
0x1 0xF user defined
So tried 0x19;"Movie - Action" in /usr/share/kodi/addons/pvr.mythtv/resources/eit_categories.txt
Cycled kodi (is this necessary?)
but it still comes up as adventure/western/war
Perhaps if you can explain the relationship?
ie: the mythtv listing shows the above as action.
kodi shows it as adventure/western/war
adventure/western/war matches with 0x12
how does eit_categories deal with this?
Does it get action or 0x12 from mythtv?
if its 0x12, then if I have
0x12 adventure/western/war
0x12 action
how does kodi know which one to use?
I guess the main question is, myth says action, how do we get kodi to say that as well?
Thanks Derek
