With dxva2 enabled it has microstuttering and lagging sometime.
went back to 20 oktober nighly and they play perfect again with dxva2 enabled.
Another problem in the current nigtlies is the mainmenu.
whene i go back from EPG to mainmenu i can not select anything.
my resolution is 4k, windows 10, x64 nighty.
In order to help you with your problem, please provide a
debug log (wiki).
i lost 4 full evenings in order to derterminate the stuttering problem. (changed cables, etc, etc)
finaly went back to october nighty so i cant provide a log from the current nighty.
going back to october version fixed both problems.
just wanted to report the bugs.
(2017-11-22, 11:24)propi62 Wrote: [ -> ]just wanted to report the bugs.
Your intent is good, but unfortunately Team Kodi are not members of the Tea Leaf Reading community. On top of that, our crystal ball is out for maintenance again due to another overload of requests.
So in order to be able to fix any problems in the latest nightly builds, we will need much more information than just "it doesn't work properly". Unfortunately, software bugs do not fix themselves.
ok, i understand.
so i have to wait for other people with the same problems and with log files.
thank you for kodi, i love it!
You shouldn't need psychic powers to know what's changed between those versions...
And Propi, if you want to help then you would reinstall the latest nightly and provide the log as requested.
I have the same problem with the main menu. When I finished watching a movie, the menu is not responding. After switching to my desktop and back, or using the mouse, is starts working again.
The logs show some lines which I feel like having to do something with this issue:
Quote:13:41:25.323 T:4236 NOTICE: CVideoPlayer::CloseFile()
13:41:25.323 T:4236 NOTICE: VideoPlayer: waiting for threads to exit
13:41:25.332 T:10888 NOTICE: CVideoPlayer::OnExit()
13:41:25.332 T:10888 NOTICE: Closing stream player 1
13:41:25.332 T:10888 NOTICE: Waiting for audio thread to exit
13:41:25.341 T:8908 NOTICE: thread end: CVideoPlayerAudio::OnExit()
13:41:25.341 T:10888 NOTICE: Closing audio device
13:41:25.372 T:10888 NOTICE: Deleting audio codec
13:41:25.373 T:10888 NOTICE: Closing stream player 2
13:41:25.373 T:10888 NOTICE: waiting for video thread to exit
13:41:25.373 T:8156 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
13:41:25.373 T:8156 NOTICE: thread end: video_thread
13:41:25.373 T:10888 NOTICE: deleting video codec
13:41:25.500 T:10888 NOTICE: Closing stream player 3
13:41:25.510 T:4236 NOTICE: VideoPlayer: finished waiting
13:41:25.511 T:4236 NOTICE: CVideoPlayer::CloseFile()
13:41:25.511 T:4236 NOTICE: VideoPlayer: waiting for threads to exit
13:41:25.511 T:4236 NOTICE: VideoPlayer: finished waiting
13:41:25.524 T:4236 ERROR: Control 55 in window 10025 has been asked to focus, but it can't
(2017-11-23, 06:11)wheemer Wrote: [ -> ]You shouldn't need psychic powers to know what's changed between those versions...
While we obviously know what goes in between different versions and from that may even be able to make an educated guess on what set of changes have likely caused the issue, but since we don't purposely add buggy code we still need debug logs to see what exactly is failing to know what code part needs to be re-evaluated.
(2017-11-23, 17:45)jjd-uk Wrote: [ -> ] (2017-11-23, 06:11)wheemer Wrote: [ -> ]You shouldn't need psychic powers to know what's changed between those versions...
where can i find a changelog?
Github provides methods to see code pages.
With last v18 nightly some live tv channels do not work anymore. Switching back to channel that runs before let kodi crash or freeze. I notice also some light stutter when playing recorded .ts streams and in live tv. The video stutter begun with win10 fixes in nightly from 13.11. or 14.11.2017. The stutter stops when displaying osd windows.
I think the channels that not work are with 720p50.
Log
Since October i have issues to play my recorded tv .ts files for some (German) channels like NDR HD, WDR HD. Videos does not start (CU Lyric search for songtext!), while recorded .ts files from channels like 13th street HD plays very well. I halso have the issue that same German channels have jerking or studdering when viewing live. Because of the big file size i add Log into my Onedrive.
Hope the issues can be fixed.
Zip Log
I have the same Problem with DVB-Link PVR-Plugin on the most Channels and with the recorded .ts files.
The Problem was started for me with:
KodiSetup-20171124-d3be95d3da-master-x64 and i think the commits
Pull #13095 or
a947bbe
Here the Debug-Log:
Debug-Log
Do you notice jerking on the mentioned channels too? Thats what i have since Oktober.
No, this issue i not see here.
