2017-12-01, 16:08
2017-12-01, 16:53
(2017-12-01, 16:08)bicky Wrote: [ -> ]Is there any repo available that allows for streaming Channel 4 in Kodi.You can use TVPlayer https://github.com/BludhavenGrayson/repo...player.com
Have got BBC, ITV, just need channel 4
It's geo-locked to the UK only, though.
2017-12-01, 18:36
(2017-12-01, 16:53)TheGame1986 Wrote: [ -> ]got it thank's - works just fine with Smart DNS.(2017-12-01, 16:08)bicky Wrote: [ -> ]Is there any repo available that allows for streaming Channel 4 in Kodi.You can use TVPlayer https://github.com/BludhavenGrayson/repo...player.com
2017-12-01, 19:15
There's also the TVCatchup addon which isn't geolocked.
2017-12-01, 21:14
(2017-12-01, 19:15)DarrenHill Wrote: [ -> ]There's also the TVCatchup addon which isn't geolocked.Hi thanks for this - I can get TV Catchup to work using the Bludhaven Grayson repo, but no success with the Beardy Pig repo
2017-12-02, 00:00
Beardypig version works in KODI 18 but neither TVCatshup or TVPlayer work in 18 using Bludhaven version for me.
Bludhaven version works for me in KODI 17 though.
2017-12-02, 00:40
I've got the beardypig version working in Krypton under android.
So looks like it may be a bit of pot luck involved for now...
2017-12-02, 08:04
do these addons allow catch up services?
2017-12-02, 09:29
The Freeview one used to have a few (same as the uktvplay add-on also in the Bludhaven Grayson repo).
But generally no, and certainly not channel 4. All4 uses DRM and isn't add-on accessible.
2017-12-02, 13:25
I think MetalChris has a Blaze catch-up add-on. Bludhaven also has The Box Network channels (The Box, Kerrang, Kiss, etc) in his repo.
All4 and My5 use DRM which makes them no-go's.
2017-12-03, 10:28
I think he has a Quest addon too, or at least someone did.
2017-12-03, 10:43
Kodi does support DRM since v17. The plugin just needs to be updated to be able to handle that
