2018-10-17, 00:33
2018-10-17, 07:46
could you show me an detailed example which causes problems?
scraping language
movie to scrape
tmm scaper used..
with this info I could check it
scraping language
movie to scrape
tmm scaper used..
2018-10-18, 01:11
2018-10-18, 08:02
if you take the tmm internal scraper (without the Kodi prefix) it works for me?
I am sorry - we cannot offer any type of support for Kodi scrapers - we just try to execute them
2018-10-22, 16:09
@dirtydesaster I've just tested the tmdb service for imdb (TV shows) - it works for me. Do you have a detailed example where it does not work?
2018-10-22, 16:40
Feature request: Would it be possible to add -» mount iso file before scrabing the metadata. All my 3d movies are in full iso bdrips and not converted to mkv3d, to avoid the destruction of 3d subtitle depth
2018-10-22, 19:28
we try to "mount" iso files internally - but this does not always work...
if it does not work for you, you're probably unlucky here
2018-10-23, 06:42
2018-10-23, 23:16
(2018-10-22, 16:09)mlaggner Wrote: [ -> ]@dirtydesaster I've just tested the tmdb service for imdb (TV shows) - it works for me. Do you have a detailed example where it does not work?Thank you for testing. I have an example: Ballers
Maybe, I do the wrong way?
As you can see, in tmm the IDs are correct:
Now, I update my libary and tmm find a new Episode:
I click on "scrape new Elements"
The Episode-title and the plot Comes from tmdb.org (that's OK) but no Thumbnail.
But, there is a Thumbnail on tmdb.org:
https://www.themoviedb.org/tv//62704-bal...uage=de-DE
2018-10-24, 07:36
okay, now I understand
the problem is: the thumbnail is tied to the scraper source (in your case imdb) - the artwork scraper settings affect only TV show artwork.
but in your case (tmdb over imdb) I could also use the thumb from tmdb if imdb does not offer one..
2018-10-25, 23:42
I have been using TMM 3 alpha for awhile on MacOS High Sierra
Yesterday I updated Java as a normal update notice.
Now TMM 3 will no longer launch.
I downloaded the latest release 2.9.13 it does launch, all be it very slow.
I did a reinstall of Java just in case with no luck.
Any idea what may be happening?
Thank you
Thank you
2018-10-26, 00:17
when you launch tmm 3.0 black theme, the updater comes up with black letters on a black background... letters need to be white
https://imgur.com/a/i9CVVib
2018-10-27, 16:33
Hi.
How can i use this:
There is no checkbox as in movies.
How can i use this:
feature: added extrafanart support for TV shows
2018-10-28, 11:38
@mxlance which version of java do you have? the fixes for java 9-11 are not yet in v3..
@Edworld fixed in the next build
@OOmatrixOO go to settings - tv shows - images - at the bottom is the setting
2018-10-28, 14:13
@mlaggner - Sorry should have included this in the first place. Java 8 update 191 build 1.8.0-191-b12
thank you
thank you
