(2019-05-30, 07:08)bkiziuk Wrote: [ -> ] (2019-05-29, 17:29)testphase Wrote: [ -> ]i thank you for your efforts to bring this add-on, I want to try this, but after installation I got a Error Message,and I can not start the add-on.
I am using coreelec 9.0.2 do you have any idea what was wrong?
please set addon's logging level to Debug and provide the log file after the error occurs.
hi thanks for your reply and the hints about the kodi log. i managed to download it and see the actual debug info. based on this i just add the log file manuelly, maybe in the feature a check of existence of the log path can be added to a void the issue
thank you again
ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.IOError'>
Error Contents: [Errno 2] No such file or directory: '/storage/.kodi/userdata/addon_data/service.subsmangler/smangler.log'
File "/storage/.kodi/addons/service.subsmangler/service.py", line 2, in <module>
from resources.lib import smangler
File "/storage/.kodi/addons/service.subsmangler/resources/lib/smangler.py", line 14, in <module>
import common
File "/storage/.kodi/addons/service.subsmangler/resources/lib/common.py", line 30, in <module>
loghandler = logging.handlers.TimedRotatingFileHandler(os.path.join(__addonworkdir__, 'smangler.log',), when="midnight", interval=1, backupCount=2)
File "/usr/lib/python2.7/logging/handlers.py", line 171, in __init__
File "/usr/lib/python2.7/logging/handlers.py", line 64, in __init__
File "/usr/lib/python2.7/logging/__init__.py", line 920, in __init__
File "/usr/lib/python2.7/logging/__init__.py", line 950, in _open
IOError: [Errno 2] No such file or directory: '/storage/.kodi/userdata/addon_data/service.subsmangler/smangler.log'
