2018-06-15, 10:48
Content is stored on a samba share. File copy speeds in Windows <-> samba share are about 7-10 MB (mega bytes) per second. I prefer traditional Linux over Android simply because you have more control
(2018-06-15, 12:01)wrxtasy Wrote: [ -> ]- Apple TV 4K using the MrMC App - a quality setup.Would vero 4k work? Not really interested in AppleTV and I don't want to build a HTPC.
- Apollo Lake onwards - Intel i series Hardware running LibreELEC Kodi (no 4K HDR)
(2018-06-17, 10:11)wrxtasy Wrote: [ -> ]No you need something with a decent CPU package because 1080p 10bit H264 aka Hi10P Anime needs to be CPU software decoded, that is exactly why I made those two suggestions.So the Vero 4k could handle 10 bit H265, just not 10 bit H264?
A S905X AMLogic box like a Vero 4K has a relatively weak CPU, but a really decent GPU package for up to 10bit 4K HDR H265/HEVC video hardware decoding.
There is NO 10bit H264 hardware decoding included on any media player because it's a non standard video compression method used by Anime "scene" groups.
(2018-06-17, 15:30)Sam.Nazarko Wrote: [ -> ]There are improvements in v18, but it's still software decoded, so YMMV.Could you elaborate? Are you saying it is possible? Also, I remember reading a post somewhere about the HDMI cable included with the Vero 4k not supporting CEC/4k. Could you confirm this? Would I need to buy a separate HDMI cable if I got the Vero 4k?
Sam
(2018-06-15, 12:01)wrxtasy Wrote: [ -> ]- Apple TV 4K using the MrMC App - a quality setup.So the best bet is to use Apple TV 4K? The Apollo Lake's don't support 4K HDR?
(2018-10-06, 16:55)Roen Wrote: [ -> ]My understanding from this thread is that this codec has no hardware acceleration support and the CPUs on the two streaming boxes that I have will stutter due to lack of performance. Am I understanding the anime (10 bit h.264) issue incorrectly?
(2018-10-06, 19:19)Matt Devo Wrote: [ -> ]Would you be able to correct my misunderstanding?(2018-10-06, 16:55)Roen Wrote: [ -> ]My understanding from this thread is that this codec has no hardware acceleration support and the CPUs on the two streaming boxes that I have will stutter due to lack of performance. Am I understanding the anime (10 bit h.264) issue incorrectly?
yes
