2018-10-04, 05:19
Hello,
Wasn't 100% sure if I should post this here or some other Windows or audio/video forum but thought I'd give it a shot here. It is related to Kodi anyway, but I don't think it's a Kodi issue.
Anyways, setup is:
All 3 items are connected via HDMI to the ARC ports (TV & receiver).
The problem I have is every time I turn off the receiver power, the PC forgets the receiver (the receiver disappears from the Windows audio settings), then say you opened Kodi, Kodi then forgets what the audio default is supposed to be, and reverts to whatever else it can be (headphones).
So essentially, I turn off the receiver, then open Kodi, it defaults to my Corsair headphones. So now I have to go back through Kodi audio settings to set both audio output/passthrough devices again. It happens to me all the time since I got this new receiver and TV (my old stuff wasn't HDMI, receiver didnt have it, TV didn't have ARC).
I'm not used to the audio device controlling PC settings and not sure how to deal with it. This is also a gaming PC with a second monitor right by the TV, so it's not like I am leaving Kodi open all the time on a PC that isnt used for other things. I'm constantly closing Kodi and turning off stereo so it always resets the settings on me.
I want my headphones as default, and Kodi to remember the audio settings, even if the receiver is off. Is this possible?
I thought about disregarding the ARC functions and switching ports, but I use the Netflix/Twitch apps on the TV so I need ARC for the sound.
I looked through my receiver manual but can't find anything that might help, was hoping for a setting somewhere on the receiver to "remain awake" or something for communication to devices (like a wake on lan thing) so it can stay awake but low power. Or even a master setting in Kodi so that it stays the correct device even if it is not found (config file)?
Thanks in advance!
Anyways, setup is:
- Kodi v18 b2 - the issue was there in v17 as well
- Sony XBR65X850
- Onkyo TX-SR373 receiver
- HTPC - Windows 10 - i7-7700k, 16 GB RAM, M.2 SSD, GTX 970
Thanks in advance!
