2019-02-13, 20:32
(2019-02-13, 17:37)djnata Wrote: [ -> ]Uhm,ok... I will try.
Also see if you can you can play the sample in VLC or some other player.
(2019-02-14, 14:55)Momo90 Wrote: [ -> ]Hi!If you are using a dreambox you will need to be on version 3.17.0 of the addon. What version are you currently using?
After changing to Kodi Leia and switching from the vu+ to the enigma addon, streaming only works, if the box (dreambox 800 hd se) is running (not in standby).
When using Kodi 17.6 and the vu+ addon, streaming also worked when the box (dreambox 800 hd se) was in standby (normal standby, not deep standby).
I something wrong with my settings, or is this normal?
thanks
(2019-02-14, 22:16)phunkyfish Wrote: [ -> ]I am using 3.17.0(2019-02-14, 14:55)Momo90 Wrote: [ -> ]Hi!If you are using a dreambox you will need to be on version 3.17.0 of the addon. What version are you currently using?
thanks
(2019-02-15, 09:26)Momo90 Wrote: [ -> ]Ok, then please supply a full debug log. You'll find instructions in my signature. Unfortunately I don't have a dreambox and there are subtle differences between them and other Enigma2 devices. With the debug log and some other info from you I should be able to make a fix. Sound ok?(2019-02-14, 22:16)phunkyfish Wrote: [ -> ]I am using 3.17.0(2019-02-14, 14:55)Momo90 Wrote: [ -> ]Hi!If you are using a dreambox you will need to be on version 3.17.0 of the addon. What version are you currently using?
thanks
(2019-02-16, 11:51)Momo90 Wrote: [ -> ]@phunkyfish please find the log here: https://paste.kodi.tv/luforibilaYou have this error in your log:
Enigma2 Client: pvr.vuplus - enigma2::utilities::WebUtils::SendSimpleCommand Error message from backend: 'Cannot zap while device is in Standby'
(2019-02-16, 15:35)Momo90 Wrote: [ -> ]Fantastic! It works now! Thanks!The fix above for zap is a workaround. There will be a permanent fix in 3.17.1 so you can still use zap on channel change and it will be ignored in standby mode (it's just ignore's any error in standby mode).
One more thing: in the advanced tab of the Enigma2 addon the option "send powerstate on addon exit" exists. It is not possible to select, that the box leaves its state as it is. Could this be added?
(2019-02-16, 15:45)Dumyat Wrote: [ -> ]Did something change on the last update on the timer side?
Prior to version 3.17, I would generally surf my guide on a weekly basis and set all my timers by selecting the record item on the context menu. I would then go to the timer settings and change the timer type to 'One time' and manually change the start and finish times to account for timer padding. With the latest version (3.17), I am unable to change the recording type in the timer settings anymore, thus unable to change my start and finish times.
There is an option to set padding, but when I check to see if padding has been applied afterwards it's always blank, so not sure if its been applied or not. Unfortunately there is currently no info label available in Kodi for the timer padding. If there was, I could show this information on the timer screen and know for sure that padding times had been applied.
Is there a setting in the latest update that I need to change in order for me to continue setting timers in the way that I have been doing for the past 5/6 years? I a quick flick through the PVR settings, but couldn't immediately see anything that I could change.
(2019-02-16, 16:53)phunkyfish Wrote: [ -> ]Yeah, I wasn't sure if the global padding setting worked or not. I can change the padding on the timer settings (below), but when you enter the same screen after you've set the padding, those fields are always blank. So I'm not sure if that means the padding has been set correctly and Kodi is just not retaining/displaying the padding times you previously entered or if it means that the padding fields on the timer settings don't actually work. I haven't actually tested with any recordings to see what happens.(2019-02-16, 15:45)Dumyat Wrote: [ -> ]There was a bug in the timer types code which meant there were all messed up so in 3.17 I cleaned them up. It's of course possible I excluded your use case in error. If you could detail with screen shots what behaviour you are missing I can try and restore what you want now that the code is fixed.
Most users set the padding on the Enigma2 device (assuming you always use the same padding) instead of using Kodi as for Enigma2 devices there is no notion of padding when setting up timers so it's done by editing start and end times. This is problematic as start and end times can compound padding which can be very confusing.
There is also a default padding setting in the main PVR settings in Kodi but it suffers from the same compounding problem as setting them locally.
Am I right in saying you want to change a “One time guide-based” timer to a manual timer? One time guide based would be fine if you could set the padding (this may or may not be a bug, I'll have to look into it).
