Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
(2019-01-08, 15:46)fritsch Wrote: [ -> ] (2019-01-08, 15:41)nycom Wrote: [ -> ] (2019-01-08, 15:20)fritsch Wrote: [ -> ]We need c) to be installed - so that we 100% can show - that only the APP_PACKAGE_ID change was sufficient to get it going.
Btw. I really hope that you test on an affected TV :-) If the nightly run there before just fine - your device is not the valid testing TV, hehe.
a) OK
b) OK
c) KO
I tried to install the packages on a Sony KD55-AF9
Thanks much! Means, changing the PACKAGE_ID is fully enough, so that kodi runs perfectly fine on those TVS, right?
Could you do me a favor and please uninstall complete kodi again, clear the cache of the Google PlayStore App and try to reinstall the c) again?
I already tried this solution few weeks ago, it's not working.
Okay - so then we can conclude:
Changing JUST the PACKAGE_ID from org.xbmc.kodi to _anything_ else as shown in our tests makes kodi work. Do you agree with this result?
Then let's kindly wait what Sony-Engineers tell us about the reason for this. Would be funny to see it "magically" be fixed after next update ;-)
So for the moment, we just can install option a) and b), which one is better? Or it doesn´t matter?
Thanks for all this work...
(2019-01-08, 15:18)fritsch Wrote: [ -> ] (2019-01-08, 15:12)chrisyu Wrote: [ -> ]@fritsch
Test results, I use adb install from network.
a) $ adb install kodi-20190107-689e9e07-sonyamazon-armeabi-v7a.apk
Success
Runs fine.
b) $ adb install kodi-20190107-689e9e07-sonyamazon-armeabi-v7a.apk
Success
Runs fine.
c) $ adb install kodi-20190107-4abe3490-master-armeabi-v7a.apk
adb: failed to install kodi-20190107-4abe3490-master-armeabi-v7a.apk: Failure [INSTALL_FAILED_INSUFFICIENT_STORAGE: Failed rename]
Cannot install.
Thanks very much. Can you perhaps make a bit of "free space"? - and try again?
My TV z9f has enough space.
It always report this error when installing kodi official build. I tried to factory reset my TV , and still same error.
(2019-01-08, 16:53)chrisyu Wrote: [ -> ] (2019-01-08, 15:18)fritsch Wrote: [ -> ] (2019-01-08, 15:12)chrisyu Wrote: [ -> ]@fritsch
Success
Runs fine.
Success
Runs fine.
Cannot install.
I figured after posting. Thanks much. Currently building org.xbmc.sony ... curious if this also works, meaning "if they block", if they do it with == or with contains. Curious. We will find out.
Just to confirm, in post #77, link a) and b) is same url.
Is it meant to install same apk twice?
Here is the result.
And my TV is China version, there are no Google Play store on it.
a) $ adb install kodi-20190107-624d59a1-sonyrandom-armeabi-v7a.apk
Success
Success
c) $ adb install kodi-20190108-8d666add-org.xbmc.sony-armeabi-v7a.apk
Success
All run OK.
And there any difference in performance among this 4 versions?
Nope - just always latest master - the PACKAGE_ID change picked on top - and the 100% same build job as with the official jobs. Newest is the org.xbmc.sony one ...
(2019-01-08, 17:38)chrisyu Wrote: [ -> ] (2019-01-08, 17:28)fritsch Wrote: [ -> ]Perfect. Thanks.
Now please remove all and try: D) http://mirrors.kodi.tv/test-builds/andro...bi-v7a.apk <- random test-build with org.xbmc.kodi PACKAGE_ID
OK, I create a blank project with android studio, set package id to org.xbmc.kodi .
Only 2.3m in size, https://app.box.com/s/q8o7zzhp8gl3u7c52y6uhd9o21opcz8z
And here it is:
$ adb install tv-release.apk
adb: failed to install tv-release.apk: Failure [INSTALL_FAILED_INSUFFICIENT_STORAGE: Failed rename]
Hurray! This is the 100% PROOF! Can you upload the APK please? (Edit: You did, perfect)
Good - now we know: Sony blocks by PACKAGE_ID ...
So which is the one we "should" install
This goes very fast...
