(2018-11-20, 14:42)FoxADRIANO Wrote: [ -> ]I will make what you suggest me. I still don't have the new HDMI cable.
Yesterday when I wrote I solved my problems in another post it was because a friend of mine lent me a HDMI cable for one day.
Two days ago I bought a new HDMI cable and I will get it in around 10 days. It costs more that 70 euro because it is a cable of the future with triple shielding.
I'd cancel the order of a €70 HDMI cable. There is absolutely no point in spending that amount of money on an HDMI cable. A ~€10-€20 Premium Certified HDMI cable will perform perfectly with an nVidia Shield TV in all supported output formats.
I run with OMARS cables (as recommended to me by a broadcast engineer and colourist) but Amazon also do a good range of own brand cables at around the same price point.
Quote:I already got and I use a new and expensive USB3 cable and now I'm waiting for another the new HDMI cable. Now I'm using the new USB3 cable and an old HDMI cable. But I have always many problems above all with Kodi.
Expensive isn't the same as good. Please don't make that mistake.
I thought you were using a USB 2.0 cable and all your problems had gone away? Is any of your content so high bit rate that you have to use a USB 3.0 cable?
Quote:Out of curiosity: is it better having a good HDMI cable or a USB3 cable for the Shield? I remember I connect Shield to HDD.
The only reason to change HDMI cables is if you are getting sparkly dots on your video, or your TV and nVidia Shield don't connect reliably with your TV saying 'Unsupported signal' or similar, or you get flashing black / green /magenta screens when you are playing video. That is usually the sign of a cable that is failing to carry a high bandwidth signal reliably. However if you get a signal that doesn't have sparkly dots or any flashing - then your HDMI cable is working correctly. Either an HDMI cable works - or it doesn't. That's the great thing about digital signals.
Quote:Now I like to ask a last question please: could a no good HDMI3 cable give slightly faded colors and tending to blue?
No - it is not possible for an HDMI cable to do subtle colour changes.
Quote:It is what I'm getting above all with Kodi and MX Player Pro is giving me less problems.
This sounds like a difference between Kodi and MX Player Pro in video terms. Do you see the same changes between Kodi and MX Player Pro when the Shield TV is configured for 709 output and when it is configured for 2020 output?
Quote:When I use Kodi I get slightly faded colours and I always need to close Kodi 2-3 times and then Kodi works fine with colours. I almost always need to close Kodi and to open it again if I want to see good colours.
I'm afraid I can't help with this. Do you get the same issues with all UHD content you are playing?
Quote:Edit: If I understand well: if I disconnect the HDD I don't have problems in surfing into the Shield icons. My problem is only when I watch a video, the remote control doesn't work fine.
Yes - you have confirmed you have a USB 3.0/Bluetooth interference issue. When you disconnect your USB HDD you have no problems with your remote control. When you connect your USB HDD but it isn't doing anything (i.e. no video is playing) you don't have problems (this is presumably because no data is being carried over the USB 3.0 cable). When you play videos - and lots of data is carried over the USB 3 cable, you get interference issues. Just as I have advised and wrxtasy has advised.
The nVidia Shield TV - as I have said - is known to be susceptible to USB 3 interference (some people have modified the Bluetooth antenna inside to reduce this interference)
Quote:How can I connect an HDD with Shield by a Ethernet cable? Do you mean with Internet? I use Shield in tavern and the Internet signal is weak.
I mean by using a NAS (Network Attached Storage), a DIY server like unRAID, sharing your USB 3 hard drive using network sharing on a PC/Mac (i.e. plug the HDD into your PC/Mac and then enable drive sharing with your Shield TV and PC/Mac connected to the same network via Ethernet cables), or by using a hard drive with integrated NAS functionality (BUT YOU MUST CHECK THEY SUPPORT SMB/CIFS or NFS - some use their own protocol) None of this uses the internet. However if you are not confident in network set-up this might not be a good idea for you. However it is how many Kodi users operate. Almost all my videos are on a 20TB unRAID server in a cupboard that I access over my home network on all my Kodi devices (Shield TV, PC, Raspberry Pi, Apple TV running MrMC etc)
Quote:If I buy a USB FLIRC IR receiver, do I have to change remote control?
Yes - FLIRC emulates a USB keyboard. You program it by plugging it into a PC or a Mac, so that it can work with any spare infra-red remote control you may have (some people use an old satellite PVR or DVD player remote for instance, or a Logitech Harmony universal remote) and then you plug it into your nVidia Shield TV and it allows you to control the Shield TV without using Bluetooth, and thus without interference.
Quote:My Shield begins to plot a drama. Maybe in a little while I will not want to hear about Shield again.
NOW THE MOST IMPORTANT QUESTION:
Do you know if there is a better player than Shield even if it is more expensive? I will watch ONLY my 4K videos in a HDD.
EDIT 2: This night I tried to watch the same video I watched in the afternoon but this time I saw a very overexposed video. The video was very bad. I hope someone can tell me if this problem is of my old HDMI cable.
There are lots of players that support UHD playback - the AMLogic S905X/D based players are good examples. The Vero 4K/4K+ are S905X/D based and work well and Sam supports them well with his OSMC set-up. You can buy cheaper no-name boxes and run Libre/CoreElec on them too - however if you are struggling with your Shield TV and not confident as a computer user I'd look at the Vero.
However I have zero major issues with my Shield TV - certainly no random 'wrong colours' issues...
