Full Version: OSMC skin worked fine on 17.x but no longer under 18
I really like the slim look of the OSMC skin and since I moved away from RASPI3, I was happy to see I could get it to work on my new Android box. It did not straight away, cause after downloading it from Github and setting Add-Ons > My Add-Ons > Look and feel > Skin > OSMC to enable it, I got the message
The following add-ons are incompatible with this version of Kodi and have been automatically disabled: OSMC
So I copied over my installed skin from RASPI3 and selected it under Settings > Interface > Skin. This has worked just fine but does no longer under Kodi 18. Is there anything that I can do to adapt it or do I have to wait for the original author?
@Sam.Nazarko can probably advise best.
There are Leia versions of OSMC around, although I'm not sure if there is an official one or not. But those should carry suitable versions of the skin.
Thanks Darren
You can download the v18 (leia) skin here: https://github.com/osmc/skin.osmc/tree/leia
Sam
