Full Version: Did you know...? Tips to customize Aeon Tajo
Here you will find some tips in case you want to customize Aeon Tajo even more ;-)
Music in Home Menu
- You can always turn on/off this option under System/Interface/Skin/Configure Skin/
- You can also replace the default melodies with your own songs. First, create a playlist (*.m3u) in MUSIC menu item (only the first 10 songs will be played). Go to System/Interface/Skin/Configure Skin/Choose user audio playlist, and browse to your playlist.
Actresses images in video views
- Go to System/General options/General and activate this option:
- Go to System/Skin addons/Recommended and make sure you have these two addons installed:
Play themes.mp3 in movies and tv shows
- You have to turn on the option under System/Interface/Skin/Configure Skin/General
- You must provide your own theme.mp3 file and place it in the right place. For movies you should place it in the same folder as the video file. For tv shows you should place it in its parent folder, like this...
- The skin needs a little addon that gets installed automatically when installing the skin. It's called script.check.theme. If you still have problems after taking into account the former steps, double check that you have that addon installed.
Characterarts
Aeon Tajo supports characterarts in movies and tvshows views. The best way to get them is to use Artwork Beef addon: https://forum.kodi.tv/showthread.php?tid=258886
After configuring it properly in Settings, you'll have to run the addon and select 'Add missing artwork for...' and then 'All videos (new, old and all in between).
