2019-03-31, 02:52
2019-03-31, 06:56
This skin looks phenomenal! I hope you are able to see it all the way through. Best of luck to you.
2019-04-01, 02:31
2019-04-01, 07:00
2019-04-01, 07:05
Nice use of blurring there.
2019-04-01, 20:08
Great job! The skin looks beautiful.
I have a problem though, I am trying to install it on Krypton. When you say first install the resources and then the skin what do you mean?
2019-04-01, 20:37
(2019-04-01, 20:08)zacharisharris Wrote: [ -> ]Great job! The skin looks beautiful.
Extract the contents of the zip file I linked to. You will find 5 zip files within. In kodi go to your settings>addons>install from zip file
Then navigate to the zips now have, and one by one install them
Start with the ones that start with resource, then install the colorbox script, then install the skin (which is titled skin.titan.aesir.zip). Then then follow the rest of the steps in the first post.
2019-04-01, 20:39
2019-04-02, 17:11
(2019-04-01, 20:39)Arcanthur Wrote: [ -> ]Here is the new list view in the music library:
Thank you! It looks great. Any chance you could look at revamping the video OSD controls? I believe something blurry will make it beautiful.
2019-04-02, 20:31
Awsome!
2019-04-03, 08:50
Looks very good in my eyes. When Leia version. will come?
2019-04-03, 13:39
The colorbox use is looking great, making titan look much more modernized.
2019-04-03, 19:18
@zacharisharris I do plan on updating the OSD, although the blur effect won't be possible with live video, due to the way the script works. We would need something implemented into the core codebase of KODI for something like that.
@sincity921 I'll look into a Leia version once the Krypton version is done.
2019-04-04, 00:15
2019-04-04, 00:19
